hah ha what ive told you is all i know :D sorry champ.
im tipping you'll be there for a while with an orbital sander though.
i think the diamond blade wet saw would be your best bet.
or a combination of drilling, sawing and sanding :(
have you tried being happy with the orange lenses? :P
  • Replies 52
  • 3 weeks later...
I've decided i'm going to drill a couple of holes close together and then try and fit a diamond blade tile cutting jigsaw piece into it and try and cut it.
I've been a bit busy lately to get back onto this project but as soon as I have some more time i'll start on it.
Im going to have a go at this too as soon as I get another set of lenses.
If I have any luck I will let you know...
I think it will just be about finding the right man for the job of cutting/shaping/manipulating that damn lense.
Cool, let me know how you go with yours if you get it done before me. I really want to have them ready by the time PSI parts have those carbon surrounds ready so I can install both at the same time.
  • 1 year later...
  • 6 months later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
