Hello guys,
I have been reading through many threads on little ways to get increased performance from a stock cooler a skyline.
There are many theories including removing panals etc. I thought we should put all the ideas on a single thread.
If you have any great ideas for stock cooler performance lets hear them!
https://www.sau.com.au/forums/topic/33542-more-flow-from-the-stock-cooler/
For Performance?
Throw it out.
For a small upgrade, water spray is the only really worthwhile thing
cost vs effort vs result that i could think of.
Moving it to the front & re-piping it is useless unless you can do it in your spare time.
Paying for it to be done is a waste.
Even though your paying for it with your own time though really when you think about it.
well i was told to take the plastic cover from the passengers wheel arch off so help the flow. So i did. Dunno if it makes a difference. I guess u could make up a plastic scoop of some sort to grab the air and direct it through the cooler. S15's i know of have this system, maybe something to think about. But yeah i dont think there is much u could do. Maybe the most effective thing to do would be unbolt it and clean it out with degreaser or something and let it dry in the sun. Get the oil film outta it
I always thought if u attached some good sized heatsinks to the outside of the intercooler that may help dissipate the heat that it generates a bit? Very ghetto mod though, but wonder if it would work? Works on a CPU :worship:
The only way it can perform better is by improving the flow to the core and adding a water spray.
Even than it is a flow restriction once the boost in increased to around 12psi so not really worth the time to play with if you are running muchover stock boost.
Why not plumb oil through it and use it as an oil cooler, then mount a nice big front mount and plumb it up to the turbo and inlet manifold.
Alternatively fill the std intercooler with cement and stich a piece of chain into in before it sets (should make a great boat anchor)
- remove and clean out thoroughly with some sort of degreaser
- Cut a hole in the perforated plastic panel behind it (removing it entirely makes the front bar a little less stable)
- make up a plastic surround to channel (force) all of the air through the core.
- definitely don't mount it at the front, waste of time and you'd look like an idiot :worship:, also it will actually get better airflow in the stock pposition where air can flow "through it" and out the back
- as mentioned, a good upgrade (& cheap) is an r34 gtt intercooler.
the panel at the back and the ducting is a good idea. The cooler is pretty crappy in design, it's size isn't too bad tho'. The R34 intercooler is slightly larger but suffers from the same crappy end tank design and core, should work a little better all the same.
instead of water spray, why not mount a small electric fan behind it to suck air through (ie a fan from a motorbike)... cheap although probably most effective at helping the intercooler cool off ffrom heat soak, rather than reducing the intake temp
- definitely don't mount it at the front, waste of time and you'd look like an idiot :(, also it will actually get better airflow in the stock pposition where air can flow "through it" and out the back
i agree wholeheartedly with the above however, the best material for making a duct to surround the IC is 1mm aluminium sheeting. it is quite easy to work with & cheap when you ask for offcuts.
Speaking as someone with no idea; this one sounds good. Anyone else think so?
No :D
The fan would push less air through the core than the airflow at 60kph
Great when sitting in traffic but then the fan would be a restriction once you start moving again :Oops:
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
