you're kind of right and kind of wrong there, fyi
the oil system is closed so it doesn't matter whether you take a reading on the pressure from the sensor in the block or from an aftermarket gauge that has it's sensor in an oil sandwhich plate between the block and oil filter, it should be exactly the same reading no matter where it's taken from
a leak will allow pressure to release from the whole system so it won't matter where you sensor is you will be able to see the change in pressure.
your joking right, the leak was from the cam covers? by your logic you could plumb your oil pressure gauge into the pcv piping and it should be accurate.....
  • Replies 44
Yeah my oil pressure gauge is in my catch can cause i didnt wanna drill into my rocker cover ;):)
As said earlier, the standard 32 oil gauge is just there for show unless you cough up the $170 odd for a new sender plus fitting. Lets face it, if the oil pressure was really that low, the engine would be dead..
Thats what i was thinking i figured i would at least be able to hear some knocking or something.
Wednesday im going to hook up an aftermarket oil press gauge, i will let u know what happens. but for now i have to just hope its not the oil pump.
lol..
Mechanic finally got around to reading my oil pressure and it was the gauge playing up. :thumbsup::P:(:D Oil pressure is still a little bit low but nothing to worry about, i think its just because its due for an oil change. It has 10W40 thats a year old.
Yeah the factory oil pressure gauge is a bit hopeless sometimes. Mine goes down to zero every now and then. Always scares the shit out of me but I soon realise it's just the gauge being gay and after a bit of a bootful it returns to normal lol.
Edited by PM-R33
i have only read the first page
this is normal, mine reads the same, sometimes double, guages are always faulty
when warm mine sits in the middle of the first section like ur image, then when running goes up, but hey maybe my oil pressure is to low lol
  • 3 weeks later...
  • 1 month later...
I've red this thred, and i own a r33 gtst with a n1 oil pump and i have the same problem, i use mobil one 15w-50 full synthetic oil.
Is this model of the skyline prone to a bad gauge as well? after a good beating the car oil pressure is midddle of 0-quarter mark. I'm thinking of dropping the crank changing out my acl bearings for new ones, change the oil pump to a greddy unit that i have. and while i'm at it, place a crank collar on the crankshaft for the new pump.
What is the recomembed oil pressure in psi at idle for a gtst, as i will check it with a manual gauge first?
Mine sits at like 30-50psi I think on idle depending on temp.
I'm looking at changing the pressure sender to something aftermarket so the gauge reads more accurately and also to hook up to the Vipec as an input so if it detects oil pressure to be too low to shut down the engine.
Edited by PM-R33
has any thing changed are you running, a n1 oil pump? like i am.
I like you wheels mate, if you don't mind can you let me know the specs on them size name and type offset front and rear tyre size.
thanks looks like 10 j in the rear. I'm guessing that there s1's.
before you go changing oil pump and bearings and crank collar etc spend $200 on a quality oil pressure gauge and sensor. mount it, check it and see what is really happening with your cars oil pressure. the factory guages can be great, or they can be shithouse. but even when in tip top condition they are painfully slow to react (this is so normal drivers don't get scared by the rapid changes in oil pressure). buy a proper gauge and then decide if you really have a problem or not.
like a few others my guage show really low sometimes. i was just wondering what the pressure should be at while idling n driving on highways and such! after reading this thread im going to try get an aftermarket oil pressure guage today and check it all properly but i need to know what would be classed as a good pressure?? thanks guys
Ok guys I did it, I placed a 3way splitter where the original sending unit was on one end, I added -4 an adapter on the other end, I changed the oil and filter Mobil one 15w-50, I then started it up and, it went to 85 psi right away, after letting it idle for a while it sat at 65psi for a long time. At this point it wasn't too warm, so I took it for a ride at 26psi of boost, beat it a little, and then return home. The factory gauge was sitting just slightly under the quarter mark, and the analog gauge that I add was reading 40 psi. From what I read this should be fine.
It wasn't easy getting these fittings to fit. There is no room, and I found it easier to do it with the filter off, so that's why I just changed the oil. the gauge i added does have a faster response than the factory one. After i drive the car for a little while more, and the oil wears a little, and the factory gauage goes to half of the quarter mark, thats when i will let you know my findings. thats the test piont. nismo N1 oil pump is what i have.
thanks everyone for all your help.
Edited by MJTru
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
