  mr 32 said:
haha go me on the gtw, need to tighten my hand brake for next time for the other courses
well i actually think its got a little bit more in it, i had a fair amount of wheel spin off the line and i was short shifting aswell
Give me the keys for the GTW. Sorted :D
  • Replies 255
Posted Images
  nerm said:
I was timing Morning Course 2 and I'm pretty sure you were 33.5 (Mell's car was 33 and you were driving it, hence the .5) I don't remember what the time was but it was up there.. I would have to have a look at the original time sheet (or a copy). From memory Reece was first in the Skyline, second in the Clio, Mitch was third in the Skyline then you were fourth, then Reece in the Clio in reverse was fifth (although it looks as though the times for the Clio in reverse were not included in the above results).. but that is just from memory, it may be slightly bais.
EDIT: I just had another look over the times and I would say that you have been put down as '34'. I remember that you started off slow and have a few tries before you got your good time. It would also mean you had the fourth fastest time which is what I said above :D
Ha ha ha, yeah I had a few goes where I spun the first two times, then nailed it pretty well two times after that...
I just wasn't sure, thought those times could have been someone elses... :D
Thanks MEL!
Thanks MEL!
Pinky Rules!!!
Apart from a single lunch-time blast in MSD00F's MX-5 (thanks again, Anna!) just before the battle courses were set up, the only burning and thrashing I did on the day was burning the sausages on the BBQ, and subsequently thrashing all your taste-buds as you all ate them. Many thanks to BenM and my little sister Rosie for help with the BBQ on the day!
Oh well, next time I'll be out there giving the wagon another hiding, and hopefully I'll have some other Stageas along as well, and NOT just sitting in the car park.
  Wacky Dee said:
does anyone know of any upcoming skidpan days organized by any other car club or been to one? I don't care what car club it is .. I'd just love to give it another go before the car sells ;)
Driftmob are holding a drift day at EC in a week or so
http://www.driftmob.com.au/forum/viewtopic...f=23&t=3060
  N1GTR said:
The setup we use is the only setup like it in Sydney.
The alternatives are drifting style or state champ style (competitive short tight course la that aren't as skyline friendly)
that's what makes it interesting!
That driftmob day looks kinda interesting, I've done the peanut track once before in my R31 and EC peanut would not be as exciting as Texi. I haven't made any enquiries cos I haven't seen any SAUers post that they're going :P
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
