Hi Guys,
Just noticed a spot on the car which looks like little bubbles and are kind of sticking out creating a rough surface.... I assume this is rust... It is just to the left of the rear quarter window and its doing my head in!
Is this common? Anyone else had the same problem? And how can i get it off !
https://www.sau.com.au/forums/topic/336741-rust/
Ok good to see someone has also experienced it in the same place... now HOW do i get rid of it?? and just how quick will it spread if i dont get to it? Well how long do i have until it wrecks the car pretty much is what i am asking...
Any advise appreciated !
https://www.sau.com.au/forums/topic/336741-rust/#findComment-5446080
go to a panel beater. the actual amount of rust will be much larger than what is visible. a panel beater will be able to remove the rust (grind it back to where it is metal), and if it has penetrated all the way through the metal then you can have the hole welded up. if it is too big then they will cut a section out and weld a new piece in.
i recently had two bubbles of rust removed from around the rear window of the missus pulsar. this is what they did. this is also the only way to get rid of the rust.
https://www.sau.com.au/forums/topic/336741-rust/#findComment-5446203
^^^ And go over the car with that panelbeater to check over other spots. Once rectified, you can rest easy.
Next time you buy a 'Line, get VINs Fasted to check on which Japanese Prefecture the car came from. North Honshu & Hokkaido = salt!
https://www.sau.com.au/forums/topic/336741-rust/#findComment-5447884
  • 3 weeks later...
rust:
rear wheel wells
inside car forward of seats in sills. happens when the car is jacked up wrong- fix is new sills in/out affects BOTH sides
C Pillar towards rear of car where glass meets body - BOTH SIDES
rear panel under tail lights and licence plate area - more so if its had a tap.
chassis rails - especially if they are crushed.
Roof around sunroof area
thats most of mine.
the minor rust can be cut out and fixed - any competent panel shop can do that with a grinder and brass.
the major stuff - new parts.
https://www.sau.com.au/forums/topic/336741-rust/#findComment-5483039
+1!!
https://www.sau.com.au/forums/topic/336741-rust/#findComment-5483043
the reason why you have rust in certain window, boot and seam areas is because they use a sealant to stop water getting in, as it brakes down in the years water will stay there work its ways though the paint and primer and cause rust.
so in conclusion pending on age and last time it was applied reseal all these areas if you dont want water build up causing rust
https://www.sau.com.au/forums/topic/336741-rust/#findComment-5483094
Bit of a misconception that its just Northern Honshu & Hokkaido is only place for salt.
They pretty much spray salt on highways over winter in Kanto, Chubu,Kansai regions but definitely its for a longer period in Hokkaido & Tohoku.
The thing you do get down Honshu is rust from coastal areas.
https://www.sau.com.au/forums/topic/336741-rust/#findComment-5483116
Thanks Mark, for upgrading my knowledge. :ermm:
https://www.sau.com.au/forums/topic/336741-rust/#findComment-5485919
  • 5 months later...
panels are $800+ a side and then labour/paint. if you can't do it your self expect a 4 figure repair bill.
I am in process of doing mine and that is :
roof ($700)
rear drivers quarter : $800+
sills $1k set
inner B-C brace $300
rear beaver panel $300.
that is PARTS ONLY. I'm doing the removal myself.
should give you an idea.
https://www.sau.com.au/forums/topic/336741-rust/#findComment-5738701
    • Some of the filler.   Also if I look under the top flap of metal it starts looking good quite close to the edge. I get the feeling it doesn't go much further.
    • So, I finally started digging at the bit of my roof that was cracking and bulging a bit. Well, it was just thick filler that was covering some pretty bad rust. I didn't find the edges, I was too bummed to keep going.  There are a few holes as you can see. There was just so much filler but looks like no attempt under the filler to prime or use rust converter, just slapped filler on exposed rust.  Anyway, I'm going to take the windshield out and find the edges. I'd love to fix this myself as I'm pretty sure it'll be expensive to get done properly. I was thinking I could just get a cut piece from another E39 and just weld it in place as it would be the right size and shape.  Thoughts?
    • This is the territory of the "Stage 1/2/3 Golf GTI/R" or otherwise off the shelf tune with (relative to before) minor mods. It's easier now. Downpipe and Tune and boom, big increases. Stage 1 OEM+ is where it's at. This is where the niche evolved into and it's really easy to see why. It's rare to even NEED to consider changing turbos or going to aftermarket ECU's or building bottom ends for more power. Stage 1-2-3 will get you a LONG WAY. Civic Type R turbo GR Yaris/Corolla Anything with B58 (MKV Supra/x40i) Anything BMW in General Anything Audi in General Any turbo AMG RenaultSport Turbo offerings Korean Elantra N/I30N Ecoboost Mustangs Focus RS? List goes on. I would argue in the future it won't even need to go on... M3P is pretty rapid out of the box...
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
