Darren83 Posted September 15, 2010 Share Posted September 15, 2010 Hi Guys, I know the getrag have been covered quite extensively, but so far i have not come across any threads that i can find on the issue. Went to my mech to top up additional RP Synchromax of 1 ltre from the side ( the gearbox itself) as previously the supplier ran out of RP. Driven the car for about 30 mins from my place to the workshop, mech jacks the car up and loosens the drain plug. He is absolutely surprised as to why the oil is draining out as previously he only filled in 1 litre in and it should not be draining out as the level of oil is only half ( He put his finger in and felt its half full) As he previously have seen the GETRAG boxes opened up, he realized there is a connecting hole from the transfer case to the gearbox. Ie anything more than 2 litre that is filled from the gearstick, excesses will be flowed into the gearbox section. Im just wondering if this is true ,and if anyone has completely drained all oils ( from transfer case and gearbox) and fill the full 4 ltrs of oil straigt into the gearstick. It was abit notchy before i reached there, but once the full 4 litres is filled in from the gearstick, i do realize gear change is very smooth. Any similar experiences from you guys? Thanks Link to comment https://www.sau.com.au/forums/topic/336888-filling-the-6-sp-getrag/ Share on other sites More sharing options...
T04GTR Posted September 15, 2010 Share Posted September 15, 2010 i didnt know the gearbox shared the same oil, r34gtr i worked on recently has seperate fills. redline yellow in the box and redline aft in the transfer..... the fact that both oils are probably red in your car, you could have no oil in the box.... and way to much in the transfer. Link to comment https://www.sau.com.au/forums/topic/336888-filling-the-6-sp-getrag/#findComment-5448195 Share on other sites More sharing options...
Darren83 Posted September 15, 2010 Author Share Posted September 15, 2010 i didnt know the gearbox shared the same oil, r34gtr i worked on recently has seperate fills. redline yellow in the box and redline aft in the transfer.....the fact that both oils are probably red in your car, you could have no oil in the box.... and way to much in the transfer. Yeap, they share the same oil, to add to that, when we drain the oil from both gearbox and transfer case, they both had the exact same color and oil thickness(very subjective though). And yes the colors are red from factory. If (currently) there is absolutely no oil in the gearbox, should i be experiencing a very notchy feeling? Didnt fill in any oil from the side, all 4 litres is filled from gearstick, the connector hole will overflow the excess to the gearbox. Link to comment https://www.sau.com.au/forums/topic/336888-filling-the-6-sp-getrag/#findComment-5448212 Share on other sites More sharing options...
paulR32gtr Posted September 15, 2010 Share Posted September 15, 2010 You 100% sure about that? the transfer should have auto-transmission fluid in it.. Link to comment https://www.sau.com.au/forums/topic/336888-filling-the-6-sp-getrag/#findComment-5448352 Share on other sites More sharing options...
Darren83 Posted September 15, 2010 Author Share Posted September 15, 2010 You 100% sure about that? the transfer should have auto-transmission fluid in it.. The transfer is using an ATF specification fluid, ie the RP Synchromax. Just need to know if, filling via the gearstick really does overflow to the box and will overflow the right quantity. Link to comment https://www.sau.com.au/forums/topic/336888-filling-the-6-sp-getrag/#findComment-5448374 Share on other sites More sharing options...
Moodles2 Posted September 15, 2010 Share Posted September 15, 2010 You do realize, when you are filling through the gearstick with a GTR, you are filling the transfer case, not the gearbox as what would happen with a RWD skyline? Also the notchyness can be attributed to not using the proper fluid for the Getrag box as it expects ATF fluid (V160 from Toyota, same as what used in the Supra's 6 speed Getrag) not a gear oil. Link to comment https://www.sau.com.au/forums/topic/336888-filling-the-6-sp-getrag/#findComment-5448404 Share on other sites More sharing options...
Darren83 Posted September 15, 2010 Author Share Posted September 15, 2010 You do realize, when you are filling through the gearstick with a GTR, you are filling the transfer case, not the gearbox as what would happen with a RWD skyline?Also the notchyness can be attributed to not using the proper fluid for the Getrag box as it expects ATF fluid (V160 from Toyota, same as what used in the Supra's 6 speed Getrag) not a gear oil. Yes, i realize im filling the transfer case, and im sure the fluid is proper (RP Synchromax) and the notchiness is only prior to the oil change. After the change, its smooth and alot better. However, the issue to note here is if by filling the full 4 ltres in the gearstick, will that 2 litres be flowing over to the gearbox, as the mechanic have sworn when he opened up the gearbox, there is a connector hole between the transfer case and gearbox, Link to comment https://www.sau.com.au/forums/topic/336888-filling-the-6-sp-getrag/#findComment-5448414 Share on other sites More sharing options...
BezerkR32 Posted September 15, 2010 Share Posted September 15, 2010 as already stated when filling through the shifter you are filling the transfer. there should be a seperate fill and drain for the box. Yes, i realize im filling the transfer case, and im sure the fluid is proper (RP Synchromax) and the notchiness is only prior to the oil change. After the change, its smooth and alot better. However, the issue to note here is if by filling the full 4 ltres in the gearstick, will that 2 litres be flowing over to the gearbox, as the mechanic have sworn when he opened up the gearbox, there is a connector hole between the transfer case and gearbox, Link to comment https://www.sau.com.au/forums/topic/336888-filling-the-6-sp-getrag/#findComment-5449292 Share on other sites More sharing options...
doo doo Posted September 15, 2010 Share Posted September 15, 2010 just had the transfer case off the R32 GTR and it's completely sealed from the gearbox. There is a hole in the back of the box but it goes into the space between the box and the transfer case where the g'box oil lubricates the driveshaft connection in to the transfer case oil pump. This space is still sealed from the transfer case itself. Here's a pic of the plate that separates the case from the box. The top hole has a seal and is for the striking rod, the one below has the oil pump for the transfer on the other side and the driveshaft from the box goes in here, the other is for the front drive shaft. hope this helps Link to comment https://www.sau.com.au/forums/topic/336888-filling-the-6-sp-getrag/#findComment-5449301 Share on other sites More sharing options...
turboedsloth Posted September 15, 2010 Share Posted September 15, 2010 The transfer on this gearbox should be 2 sealed units separate from each other. Which is why they have 2 separate fill and drain plugs. There is no connector hole. They should have a breather on top of each unit Link to comment https://www.sau.com.au/forums/topic/336888-filling-the-6-sp-getrag/#findComment-5449404 Share on other sites More sharing options...
Duncan Posted September 16, 2010 Share Posted September 16, 2010 maybe the seals on one of those connecting holes is blown. btw why did a "mechanic" put more than 2l of oil in a transfer case? Link to comment https://www.sau.com.au/forums/topic/336888-filling-the-6-sp-getrag/#findComment-5449593 Share on other sites More sharing options...
paulR32gtr Posted September 16, 2010 Share Posted September 16, 2010 This is however a Getrag - different to our R32 / R33 5-speeds. Seeing that is uses ATF instead in the gearbox instead of gear oil it is conceivable that the Getrag has a connection between the two. Maybe PM someone like Snowman - I know he has dealt with the 6-speeds. Link to comment https://www.sau.com.au/forums/topic/336888-filling-the-6-sp-getrag/#findComment-5449983 Share on other sites More sharing options...
Darren83 Posted September 16, 2010 Author Share Posted September 16, 2010 maybe the seals on one of those connecting holes is blown. btw why did a "mechanic" put more than 2l of oil in a transfer case? Thanks for the reply guys, when the mech tried to add in more oil at the side, (via the fill plug) oil is already leaking out, his explanation is that it shouldnt as previously when he opened the fill plug, the oil is still below the mark, it shouldnt leak out. He put more than 2l of oil in the transfer case because he is under the impression that the oil will flow into the gearbox once the transfer is full. Link to comment https://www.sau.com.au/forums/topic/336888-filling-the-6-sp-getrag/#findComment-5450218 Share on other sites More sharing options...
Spurdo Posted September 21, 2010 Share Posted September 21, 2010 He put more than 2l of oil in the transfer case because he is under the impression that the oil will flow into the gearbox once the transfer is full. i think you'd want to know that he's absolutely 100% certain about these things, rather than "under the impression" Link to comment https://www.sau.com.au/forums/topic/336888-filling-the-6-sp-getrag/#findComment-5458428 Share on other sites More sharing options...
T04GTR Posted September 26, 2010 Share Posted September 26, 2010 ok, then why on the r34gtr i serviced had yellow redline oil in the gearbox, and red atf in the transfer case, both with seperate fill points.... Link to comment https://www.sau.com.au/forums/topic/336888-filling-the-6-sp-getrag/#findComment-5466590 Share on other sites More sharing options...
T04GTR Posted September 29, 2010 Share Posted September 29, 2010 hows the progress? Link to comment https://www.sau.com.au/forums/topic/336888-filling-the-6-sp-getrag/#findComment-5472071 Share on other sites More sharing options...
