Carbon Fibre S2 Front Foglight/indicator Surrounds Group Buy!
Ah ok, was just thinking that because parts like CF bonnets weren't legal these might not be. But then these aren't exactly doing much in a crash :) all good!
As soon as 10 people are gathered PSI parts will start manufacturing them as that is the minimum required. So there kind of isn't a date as such....is that cool?
If not I can put a date up, but we only need two people anyway so it would be a safe bet it would be filled this week.
I understand there but there needs to be a 3 month cutoff date for even a EOI - otherwise a EOI could run for 6 months.
Ok no worries man.
Cut off date to get the 10 people needed will be until next Friday the 8th October. If another person aint found by then I will put my name down for two so we can get these manufactured :down:
Edited by PM-R33
Rigteo, need two more people then. Guys ask some of your friends or something, surely out of the millions of Skylines in Aus there are two more people that would want these. Don't make me have to buy three lol.
Edited by PM-R33
ill chip in for the other one, we'll just leave em available for 2 others when they come along
Yeah righteo. I'll let send Shane a message saying we have 10 ready for purchase :)
BUY LIST
1. PMR33
2. EIRESGAUS
3. NA BEAST
4. DELLJIT
5. SSXRICHO
6. 75COUPE
7. AHH 33 S2
8. MSTRSHENANIGANS
9. PMR33 (Extra set)
10. NA BEAST (Extra set)
GROUP BUY IS A GO!
I have spoken to Shane from PSI parts and they are sending the covers to get the moulds created since we have 10 kits on order :rofl:
So here we go.
The carbon surrounds have been added onto PSI Parts' website as can be seen here:
http://www.psiparts.com.au/detail.htm?ProductID=R33S-FOGL-CF
You will notice that they are at a RRP of $199 + $20 freight = $219. However our price is $119 + $11 freight = $130. This means a saving for us of $89 due to the initial group buy.
To receive this saving, a coupon must be used: R33FOGSAU
Here is a link showing how to use the coupon:
http://www.psiparts.com.au/faq-coupon.htm
And here is a link showing how to shop on PSI Parts' website:
http://www.psiparts.com.au/faq-additem.htm
So if everbody could start paying for them ASAP, the sooner we can all get them :D
If you have any questions feel free to forward them to me or to Shane at PSI Parts.
(Remember, more people can still join the group buy, just put your name down)
Thanks guys :(
Phil
Edited by PM-R33
I went to order it but when i enter the coupon code it says "Coupon Expires"
I have fixed the error, please try again.
Thanks,
Shane
I'm going to assume the coupon will work until the first batch has been made (as in this initial group buy) and is ready to ship out. Similar thing to the carbon cooling panel. You interested in a set?
I will make payment from next weeks pay :P
Edited by PM-R33
So is there actually an expiry date for the coupon or is it there all the time?
The coupon is only valid for the first batch and I will make it expire on the 22/10/10, so that gives you until Friday fortnight to get your order in.
Thanks,
Shane
Yes please :(
So you willl take NA Beasts extra kit and the next person that joins in will take my extra kit.
BUY LIST
1. PMR33
2. EIRESGAUS
3. NA BEAST
4. DELLJIT - Paid
5. SSXRICHO
6. 75COUPE
7. AHH 33 S2 - Paid
8. MSTRSHENANIGANS
10. AAARGH 33
Edited by PM-R33
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
