Yo yo.
R34 GTsT. 3" turbo back exh- Walbro 500 hp pump- JustJap Turnflow FMIC- Mushroom filter in box- Standard ECU, Injectors and AFM- Greddy profec B- Greddy RS BOV plumbed back into intake.
I've been having some real headaches with how my car puts down the power. In a nutshell, anything over 7psi (my Hi boost is set to 9,5) turns my car into a pig rich fuel guzzling, retardation machine. At first I thought it was R&R, and changed my plugs, AFM, and got hold of another standard ECU. Coilpacks are fine, and no boost leaks as boost comes on consistent and strong.
So I took it to Pulse Racing to see how it looked on the dyno. Check out the pics attached. Their Dyno reads at it's lowest A/F point of 10:1. My cars AFR flatlines at 10:1 or possibly lower right from the beggining of the run. Check out the crazy power dips to and a max of 126 rwkw.
I need some help in getting some ideas what the problem could be. Replacement standard ECU made no difference, and simply "chucking in" an aftermarket item isn't going to fix the problem either...
Tuner recons it's not the 02 sensor, coils, plugs, boost control, but pretty much tried to "sell" me the idea of an aftermarket ECU, which really, is a bandaid fix to the actual issue. I want to diagnose the cause of the issue. Any help is appreciated
Cheers
https://www.sau.com.au/forums/topic/338107-worst-dyno-results-ever/
First thing I saw was Walbro fuel pump, did you use the stock wiring (6v / 12v depending on load) or did you give it alternator voltage like A/M pumps such as Walbros need?
i hardly think theres any problems with lack of fuel flow looking at the graph....
Yo yo.
Cheers
Are you sure the injectors are stock? Something doesn't add up... Checked fuel pressure?
He suggested an aftermarket ecu because he cant adjust anything without it.
To Moodles2, It was happening prior to the Walbro pump install, and if anything, it's getting too much fuel rather than not enough. the Pump was installed by Autosport engineering, who I dare say know what their doin. It wasn't a backyard job.
To Scotty, I haven't checked if the Injectors are standard. I would assume so as but will check that out for sure.
My thoughts are it's not necessarily the ECU at fault here. yes i kno that their is a safe map for knock etc with the Nissan standard unit, but there is no way that the map is "lets drop AFR to 10:1 through the entire rev range"
Get an ecutalk or other consult reader and get some idea of what is going on - injector duty, afm readings (can you swap out the afm with someone?) And get a Nistune chip so that you can actually try to tune it. It will also help to identify problems.
How has no one mentioned the fact he thinks he owns a R34 GTST? :D
Haha yeh i noticed that.
So is that run on stock boost?
Did u try running a higher boost setting. Like 12 ?
Check coolant temp sensor too. Its like its on cold start enrichment
check the boost sensor is hooked up, and secondly that the boost source for the BOV is connected. If either are missing it will do that... as will a split hose (cooler)
Second dip is normal as the std ecu has a big timing drop in i, run std boost and dip goes away... or a quick remap removes it straight away.
yes
ECR33 has excess airflow protection
ER34 has excess airflow protection
ER34 also has excess boost protection via the 2nd map sensor that runs to the ECU
its likely you are just tripping that out, youll need a remap, a map sensor cut device, run it no where and crimp the vac line or get a stand alone
Lo boost on Greddy - gain 28% set gain 13% Start gain .46 gives me about 7.3 peak boost
Hi boost on Greddy - gain 38% set gain 18% start gain .55 gives me about 9.3 peak boost
Running "lo" boost is fine
Running "hi" = what you see on the dyno charts
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
