replace 26 sump with sump from rwd RB engine series, minor mod to the rwd sump to have room for oil pick up. Lots of $$$ required to purchase 26 engine then do the conversion, so build a full rb30 works out better for rwd. :O
  • 5 months later...
Thing is if you build up an RB30 bottom end, which all costs $$$ you then need a turbo to make power. If you buy an RB26, even with the std turbos you can make 250rwkws.... i dont know, cant decide myself, but i suggest you make up your mind for sure before you start buying parts...secret to doing things at the right price, ie cheaply is planning, which issomething i havent done well
Dont forget things like rxhaust, IC plumbing, clutch...al adds quickly to the cost....and speakin to someone who had done this conversion recently, he seemed to believe modifying the std sump is better then modifying the pick up.
go to force induction discussion and read the thread "rb30". cheaper and can say better than go for a rb26 for a gts-t
Not necessarily. If you can get a good condition Rb26dett at a reasonable price I would say the conversion would be cheaper. But if the engine blew up after you'd put it in then it would get very expensive. May also fetch more money on resale as the "oh its got a GTR engine in it" might appeal more but that is debateable.
and also what llwells said above. .. they're differnt engines with different strengths and weaknesses.
replace 26 sump with sump from rwd RB engine series, minor mod to the rwd sump to have room for oil pick up.  Lots of $$$ required to purchase 26 engine then do the conversion, so build a full rb30 works out better for rwd. :D
hi japtaxi, can you please explain further why would we need to replace the rb26 sump?
I'm doing the conversion this month...
rb26 sump is cast, heavy, and has front diff casing+bits that you need to chop them off before you can put the engine in (you might as well add baffle plate while you at it). Whether it is legal or not depends on the engineer/your state vehicle mod law. Compare to rb25 sump, it is sheet metal, lighter, easier to chop/weld, add baffle etc etc.
There's always the option of rebuilding a R32 RB25DE with a set of forged pistons to hold big power.
While your there throw a set of RB26DETT crank and rods in there. Not sure if the crank is needed, I think just the rods. Its been covered here on SAU many times.
Or throw a thicker headgasket in to the stock R32 RB25DE motor, bolt on all the rb20 sensors and off you go.
Sure the RB26DETT is the king BUT is it really worth the extra $$ when you could build up a RB26DET using the R32 RB25DE motor for much cheaper.
+ you would have a nice fresh bottom end with a nice shinny set of forgy's in there.
I'm starting to sound like a broken record. :rofl:
im starting it next week so ill probably document it in one way or another.
once its done ill be happy to help out and answer any questions
should be a bit easier for me though, because i have a full running GTR to use so everything is there and just needs to be swapped over.
Hey mate, might be a stupid question, but why would you pull apart a full running GTR to transplant it to a GTS-t? No offense, but it sounds like sacrilege to me :D
I hope you tell us that it has a bent chassis or something, and what you mean is that the running gear is fine
ive just finished one on a r33.
we started modifying the original gtst sump and to be honest, it takes some buchery. we cut the diff off the gtr sump and welded it up, much neater and i would prefer the extra capacity.
the conversion looks simple, just dont underestimate the hours involved with all the bits an pieces u have to modify, if ur paying somone to do it, i reckon $2500 in labour is reasonable.
so working on a $5000 rb26, the conversion should set u back around $8k if ur paying someone to do it.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
