Hey guys,
Just thought we'd give you a look at what we plan to release later this month.
Our 1000hp R32 GT-R intank kit is in the final testing stages now.
It's completely made here in Australia of CNC billet aluminium.
Includes all fittings, relay, fuel pumps, filters, Gates submersible hose
Say goodbye to fuel odour in the cabin, hello to quiet operation and of course no one will even know you have it.
Simply bolt it in and off you go!
It will be priced at $1350
Also in the pipework we have the same kit to suit R33 GT-R, R34 GT-R, R33 GTS-T, S13, S14, S15, 2001 onwards WRX, FD RX-7
www.powertune.com.au
  • Replies 40
It will be exactly the same as factory, so ultimately for a circuit car you would still require a surge tank, but for the majority of big powered street cars, this will do the job and saves a lot of stuffing around.
for 1300 bucks it would want to do everything, I can see $300 worth of fuel pumps, the hose would cost 20 bucks and a bit of machine work.
I feel its over priced, when for 1300 bucks I could have 2 044 pumps (which would actually flow 1000hp worth of fuel), braided lines everywhere and a good surge tank.
Ps. not sayings its shit, its looks mint! but im not sure a single 5/16" fuel line to the rail and 2 walbros will support 1000hp
Its actually quite reasonably priced in my opinion. That part of my fuel system cost alot more than that, seeing how its all custom.
This is a straight bolt on solution with all the guess work taken out.
X2. Its neither an arse nor an elbow. Not suited to track work and way too pricey for what it is for a street car.
What he said, Im looking to upgrade fueling, but couldnt you add a surge tank in the mix, not many 1000hp street cars but lots of lower power cars that see the track/drags.
I may buy something like this if it could eliminate surge and supply ample fuel and still be all hidden away in a tank.
What he said. Looks like a nice, well engineered kit. But what market, BIGhp that doesnt get raced on low fuel as not o carry needless weight?!?!?! Sure you will still sell plenty as a well engineered fuel system saves a lot of labour costs
Edited by Roy
i am a week or so from doing a surge system , and in my opinion ( that's right mine) its too costly for what it is , i rekon with a few hours i could knock that up and add 2 bosch 040's and away u go.
and just for example .
surge tank with mounting brackets for 2 bosch 044's : $180 au devilered (at this price hardly worth making my own)
2 bosch 044's 200 bucks each
few ods and ends
+ this actually stops surge issues , i cant see how that system will
so well under 800 bucks u have a fuel system thats rated to well over 1000+ hp
not taking credit away it is a good idea, but i just don't think it would a big seller
Edited by yogibear
c'mon Roy, 90% of big hp cars don't see the race track at all, 9% see it on the internet only. I guess 1% may visit a track once. 3 big hp GTRs in Aus regularly do track work.
so there is a market for this.
And you can be sure that billet fitting for the tank lid that seals properly costs a mint to produce. Looks excellent and much safer than the dodgy fittings most people use
On the positive side it looks well made..but does not address the fuel surge issues as already said & it is overpriced for what it is.
If the price was considerably lower it probably would be a fast selling item ..im sure people would overlook the surge side of things not being addressed if it
allowed them to supply the fuel demands needed at a reasonable price.
Exactly, if it were well under 1000 bucks It would sell like hotcakes, Hell I would have been asking about them for R33s if I still had mine.
It looks really good but like everyone else I'd be worried about the surging issues as my 33 is used for drift. May be interested once more details are released as was looking at going bigger pumps etc as i'm looking at changing to E85 and aiming for 400+rwkw.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
