Hey guys,
I've got a 1995 R33 GTS-4 with a fair bit of work done to it, so its the only reason I'm not selling car and upgrading to a GTR.
Just wondering as its AWD, whats the best option to turbo the car and costs involved?
1. GTR Front Cut (RB26 Engine and gearbox)
2. Stagea RB25DET (AWD)
3. R34 RB25DET NEO
Ive already got upgraded GTR brakes from when I did my 5 stud conversion. One less thing to do.
Any advice would be great
https://www.sau.com.au/forums/topic/340096-r33-gts-4-to-turbo-conversion/
Having started on a Stagea conversion of an r32 GTS4, because it was the "cheapest", the costs on a full RB Build up are very high, so much so that the RB26 and RB30 sump adaptor, don't look so bad after throwing dollars. Taking your NA and going plus a turbo is also worth considering if e85 is in your area. I'm more of a single turbo fan, which steered me from starting with the rb26. There are a lot of cheap gtr r33s around. I only started with a GTS4 because the price was very low.
My vote is RB30 plus adaptor because my Stagea conversion will wind up fairly pricey any way.
this is assuming he wants big power/is going to build the motor before it goes in.
I agree he needs to state the goal, if it's just 200kw atw, then na plus t or stock stagea front cut and minor up grades.
I recently completed a Stagea conversion on my 33 gts4. I found this was the least expensive way to do it. If you were to go for a 26 your would have to change a lot of gear that you wouldn't have to if you just go the 25. You do not have to change the loom and even your current radiator is up to the job of keeping everything cool. If you do end up deciding to do it I found swapping over the front diff was the hardest thing to do as I decided to stick with the longer GTS4 gear ratio. I picked up a bare motor for about $1600 or so, and from there you can do all the mods you like. I would imagine if you choose to get all stock parts the project would come to approximately $2500.
If your thinking of doing the 25 conversion and have any questions im open for a pm.
That sounds generous, logical, cost effective and sane. I was hoping he'd want to finish with something more like this...
For now I'll be putting it in as stock possibly use Stagea engine, but I'll be looking at upgrading plenum, fuel rail, cams, turbo, cooler, injectors etc later
Any recommendations on turbos for around the 250kw power mark?
Looking mainly at Garrett or HKS turbos
HKS GT-RS
HKS T04z
Garrett 35r
Garrett 2835
Trust/Greddy TD-05
Haha, yea if you have 150,000 pounds then :blush:
HKS GT-RS
HKS T04z
Garrett 35r
Garrett 2835
Trust/Greddy TD-05
Probably best to check out the turbo upgrade thread. But for 250kw i'd say just hiflow your stock turbo. Less work required in my opinion.
HKS GT-RS
HKS T04z
Garrett 35r
Garrett 2835
Trust/Greddy TD-05
HKS kits great, what about the price.
Garrett turbos will require manifold mods to stock or a dedicated manifold, lines or a "kit" bringing it up towards the HKS price.
A high flow means stock lines heat shields, appearence when pulled over or at your first re rego.
I'm looking at Garrett turbos and am in a similar position. AFAICT -> http://horsepowerinabox.com/HPIAB2/category12_2.htm the 5th and 6th options are the only garrett turbos I have found that have the 6 bolt housing that you require.
I'm not interested in a rebuilt turbo, what other options for new direct bolt in turbos are there for RB20/25?
HKS GT-RS
HKS T04z
Garrett 35r
Garrett 2835
Trust/Greddy TD-05
how much are you willing to spend?
If you do it in stages you would probably be better off just turboiing your engine, go a high flow for the power you want, spend good money on injectors, afm, fuel pump and ecu so later down the track you dont need to upgrade these again, if you feel the need for more power then you will have to add up the cost of a new engine which will depend on how much power you want.
HKS GT-RS
HKS T04z
Garrett 35r
Garrett 2835
Trust/Greddy TD-05
Get a stock Rb25 or neo turbo rebuilt with steel wheels and put it on your current engine - that might keep you happy for a while - and you can transfer it to your Stagea engine later if you decide to go that way (will make 250kw on the rb25).
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
