Date: Sun 14th Nov
Time:
Move in 9am-10am
Move out 3pm-4pm
This will be a static car display. You cannot come in later then specified, or leave earlier than specified.
Your car must be on display, and stationary for the duration of the Show'n'Shine due to the nature of the area and public safety requirements.
Entry is via Pearl River Road - refer to map below for details, "X" marks the spot where Marshals for the event will be waiting @ 9am
There is a Tram Stop right out the front as well, Route 30 or 48
Car Limit:
A limit of 80 cars is the MAX for this event. Should we run out of room sooner (due to larger cars), we will have to close the gates.[/size]
Obviously, SAU-Vic Members only. Anyone from the public is more than welcome to come along and checkout the display, however you will not be allowed to enter your car.
All cars must be Road Registered. So no towing race cars without some sort of rego.
How To Enter:
Upon entry onto the grounds you will be greeted by one of our Committee members and given directions.
If you wish to have your car in the Show N Shine and be eligible for voting you must notify our team.
You will be given a "Vote for me" sheet to place on your car with your details upon arriving.
Prizes and Awards:
Trophies will be awarded for "Best in Show" in the following main categories:
• Godzilla class (32, 33, 34 GT-R, one for each) & Best overall GTR
• Godzuki class (31, 32, 33, 34 GTS/GTT one for each) & Best overall GTS/GTT
• WRC class (WRX, Evo)
• Dorifto class (Silvia platform)
• Intruder class (other)
Use of facilities:
The following must be adhered to by all Members attending the day
- Strictly walking pace for cars, hazard lights ON at all times whilst in motion.
- No loud engine revving, starting of engines once stationary, silly compressor nuisance noises.
- No unwanted behaviour on (or when leaving) the park grounds.
- No dumping of rubbish.
IF members do not adhere to the above rules, Committee may ask you to leave. Keep in mind the club will be in the public spotlight and stupidity will not be tolerated.
Other Info:
- Bring whatever you may require for the duration, seats, hats etc. There is no leaving once you are in position until the end time of the show.
- The Piazza has PLENTY of food/beverage stores around, you will not need to go far for any requirements there.
- And issues on the day, see the people in Hi-Vis vests immediately.
Any questions please post up - see everyone there.
Cheers
Ash
https://www.sau.com.au/forums/topic/340440-sau-vic-shownshine/
  • Replies 168
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
