Heres inside the tube I back purge all my pipe work so there is no dags inside the pipe and when you get full penetration like above the welds are ALOT stronger.
I have had my Stainless tube work pressure tested at over 20bar without issue :yes:
Thanks :) yes they are all just fused no filler wire mate. I weld fairly hot but I move fast as I walk the ceramic (a welding technique) I weld tube at about 55 amps but if you are still learning id suggest around 40-45 amps depending on your welder as some are hotter than others. For welding tube id suggest getting a gas lense as it gives better gas coverage over your arc. No fancy settings just set the right amps (machine pending) I set my ramp up fairly cold at bout 20amp base temp at 50-55amp and I set my ramp down to about 3.5 seconds and my post purge to bout 5 seconds. If you look at pic above you can see where I start to ramp down the amps and continue weaving up the tube. Notice the colour change towards the end where I let the post purge cool down end of the run (the bluey colour)
When I purge I run about 5-7 lpm through the tube with basically a hole I stab with my filler wire.
Yes I used pickling paste to clean the welds but just polish it by hand with green scotchbrite pads
HAHA thanks Johnny well it is what I do for a living so id hope id be good at it lol!
To that I answer is the pope a catholic? Cash and beer are both very important parts of my life :yes:
damnnnnn Mick, that's top notch welding!
Hope you're up for some welding and payment by slabs of beer & cash lol
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
