As long as there is plenty of turbo flow and everything else to back it up, more than happy to consider it. If you like, pm me the details of the engine mod's and we can go from there.
I want to get results at different boost levels to see the overall impact. I also have an egt kit I would like to install to get even more data to back things up one way or another.
Lol funny you should mention that, I just pulled one apart an hour ago. First time I noticed them too. I figured much the same; an attempt to direct air towards the runners rather then letting it all gush straight to number 6. I would have thought they would need to be abit longer (protrude in more) to have enough of a difference.
exactly the reason why they have done it. there are some cad simulation programs results which show this would be beneficial.
as for all the air being directed to no6....this is not necessarily true considering cylinders fire at different times and the air is used only when valves are open. you will find that the rear cylinders, 5 & 6, of the gtr plenum actually flows less than the 1 & 2.
Oh good. The reason why i asked is becasue sometimes people just ask it because they think its fancy and have read it somewhere else....and I also wanted to see who could do it for me so I could compare it to flowbench figures...unfortunately your in QLD.
So that would answer your questions, no I don't but would like to find somene local who could do it for me and show me how its done...so if there is anyone out there who can, please pm me.
Interesting about the flow. I thought the major belief was that 5 and 6 flowed abit more (or atleast received air first and more of it) and so always ran a fraction leaner as a result, hence why alot of tuning shops richen 6 up by 1.5% and 5 by 1% or something like that.
Funnily enough I thought all forward facing plenums were susceptible to that problem by that same reasoning.
Did you test this by egts on each exhaust runner with matched injectors? or some kind of flow test on the manifold itself?
that is far from the truth!!!! another one of those internet created misconceptions....and there are plenty more out there
this was tested on a flow bench....EGT testing is coming with the test car
as for rb20 info, watch this space when i get some time after the rb25 testing
i actually need someone to draw them up for me to do the cfd
from reports cfd results are actually very similar to flow test results when the same environment is used, meaning real world vs what is simulated
Edited by ISL33P
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
