The single is smaller, more responsive than the twins. 6258 are capable of heaps
T4 twin scroll or just the single?
nm the bigger A/C might be a problem for my r32 and certain exhaust mani. >_<
A single EFR7670 would however be more responsive and make more power than -9s
I alays been a die-hard fan of twin application because.. well,, thats how the rb26 came out of factory.. but the more i think, it appears things have changed and single can be as responsive as the twin but cost less and easier to deal with if something is wrong.
This isn't really a specific twins versus single thing, its comparing three turbo options which aren't really comparable.
The first is the "GT2560R-9s" which are the ultimate response twins of the "last generation" of turbo tech I guess you'd call it... they flow ~30lb/min each (60lb/min peak flow combined in a perfect world).
The next is the EFR6258s which are the smallest of the EFR range and ever so slightly larger physically than the "-9s" but arguably similar in response due to design and better materials, and are rated to flow ~44lb/min each (88lb/min peak in a perfect world) - so while they are fairly close in size to the -9s, they are a newer generation and essentially targetting a way higher power level. The reason you can't get a closer flow match with twins to a -9 or even -5 setup is basically there is no EFR small enough to do it.
The last is the EFR7670 which is rated to flow around 64lb/min all by itself, so is essentially the closest match to the -9s - still capable of flowing more but is an all bells and whistles current generation turbo, nice core, twin scroll option, TiAL turbine wheel, better aerodynamics etc. so is like the equivalent of a size down in single turbo speak - but able to still outflow the -9s. If you are from the mindset that -9s are the ultimate "driving" turbo on an RB26, then an EFR7670 would probably be eye opening.... better response and moving the power potential that bit closer to -5s.
  • Like 2
Here's a fun little clip (if anyone is familiar with the old High Octane DVDs the sensor of humour and style will be familiar - this is a little tongue in cheek) with an EFR7670 showing it's worth on an E85 fuelled EJ STi WRX: ("700hp" is actually ~450kw @ 4 hubs):
He did some of the best DVD's back then! Still a crack up!
I went form STD to gt-ss, maxed them out and went with -5s last year ( i can tolerate the extra lag for the extra power but wouldn't really want to go any laggier) So I'm more interesting in the 2x 6258 vs 1x 8376 the 7670 is just too close to the -5.
And it appears the twin 6758 would be too laggy on a rb26 but well suited on a 2.8 or 3.0
Bri73y on here had (or maybe has again?) EFR6258s on his R32 GTR, he may be able to give feed back on how they respond and flow - an EFR8374 would also be awesome, sound like sensible alternatives to -5s if you're looking for more power :)
There's a guy in Canada who is running twin 6258 EFRs on a tomei 2.8L (first twin EFR in Canada) but can't find any dyno charts... Word is the kit, including oil/coolant hoses and intake pipes, cost around $8k USD. That had better kick some farken arse for more than 3x the cost of twin -5s
Bri73y still has them....
Mine have made 677hp so far on a dyno I know is low reading. My car lost near on 100hp when I first went to this dyno with no changes whatsoever.
Going back on dyno before WTAC to push some more, tuner reckons there's another 50hp in it yet.
So 700+hp on a low reading dyno for a pair of twins that spool like -5's is fairly decent. Don't know of any -5's making that kind of power.
Full Race are tuning one at the moment, it's made 630hp @ 21psi. It's also tracking well over 700hp by the time the pump 30psi into it.
It's running 280deg cams and has boost all in by 4400rpm. Not too shabby.
One of the reasons I am not sold on twins - I'd personally go an EFR8374
Is that a stoke stroke one? That is pretty serious spool for that power, again EFR6258s are very big for twins on a 2.6 - and it's pretty amazing they are comparable with -5s in spool. Going for a slightly smaller single equivalent would make for a hell of a ride imho
I believe so. Certainly RB26 was mentioned in discussion, nothing about a stroker.
EFR also make a 6255, slightly smaller than the 6258. Now they'd be fairly responsive and still make good power!!
I think he was on the waiting list for an 8374 for over a year but because 95% of GTRs running EFRs are using that exact turbo, he went a different route. Could be wrong too.
thanks for your input. I really think the decision will be 2x 62 or 1x 83 .. car still run fine on -5s and going to storage in less than 2 months so I have a solid 8 month to think or wait for more result :)
Hasn't precision turbos (proven over and over) been the best choice turbo for cost/power? I often read how they are simply awesome turbos and cost much less than EFRs while being very close in response/top end.
Hey Gents... Here is the dyno graph on the twin 6258's we are working on that John mentioned. We had to cut the dyno session short after the 28psi pull because we heard a noise coming from the CAS area and decided to investigate before another run. It's on an RB26, 280º HKS Cams and port work (standard sized valves), E85. (76% Ethanol content)
Edited by TheKeeper
No, there are just a lot of Precision fanbois that insist that without providing any solid proof. The Precisions are proven to perform really well but their prices aren't ultra cheap, their reliability is below all their competitors. I do like them but they are in cases overrated.
The only test I know of against an EFR was against a 8374 on a Supra where the testing was biased massively towards the Precision the biggest thing I remember was the EFR was a twin scroll one put onto a car which was setup for the Precision T4 open turbo, ie open manifold. Despite it being well known that doing that will do bad things to both power and spool, the EFR out spooled the Precision and made respectable power however fell a bit short of the Precision... Not sure if it would have matched or bettered it but it was within spitting distance despite being choked, so really when peopll the declared the Precision as the moral winner for being a bit cheaper and performing ad good or better, I was impressed the EFR did so well when you know that on a proper twin entry manifold it would have been a different turbo....
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
