Grrrr! Backpressure!
One day I will get around to putting some exh sensors on to find why I can't squeeze any more than 20psi out of my 8374......E85 and 40psi, now that would be fun! Haha
Chris - i just began testing the turbosmart IWG on a built subaru with EFR 7670 0.92 that couldnt hold more than 26-27psi previously -- the turbosmart worked perfectly with their high boost 26psi spring.
Look at the bottom of each chart, to see wg duty maps:
22psi:
25 psi
i know what i will be trying next on my RB26 0.92
Yeah I went the 1.05 rear with ewg because I was worried about boost control. Lets just hope its not too laggy on a 2.6!
8374 1.05 is far from laggy! 1bar boost by 3500rpm and still north of 700hp, its my favorite turbo ive had on my RB26 so far
whilst the IWG on these is game changing its a tall order to ask 600whp from.
the iwg is not what limits top end power, its the turbine housing A/R ratio
With a 50mm EWG I believe 380 is reasonable.
Keep us updated.
the EWG will not change drive pressure ratios, since there is no change to a/r
I'm going to start another thread specifically about the due to be released EFR 7163 . Many have waited a long time for this turbocharger because it promises so much and fingers crossed it will deliver .
A .
Waiting for SR20 results btw :P
Edited by Skepticism
So what are we thinking then, BW 8374 0.92 IWG on BP98? (using full race manifold)
Realistic figures for a built but standard displacement RB26, I can't get freakin' Matchbot to work on my handset ATM! (On a dynojet)
The turbo looks the gear certainly, but I am just a little bit concerned of possible lagginess coming from twins, I know the engine can handle 2 Bar/ ~29Psi no worries.
I only want a legit 400KW ATW and therefore want the best possible drive-ability for this power level.
Geoff or Lith, anyone got any ideas?
Edited by Nee-san
Well I run a 8374 0.92 IWG on BP98 but on a built RB30 and it turns out 460KW ATW on a Hub dyno at 20psi. I think on a RB26 you should see 400KW without too much drama.
I know I have 400cc more than you have, but I have much less lag than I had with -5's on a built RB26, it now has full boost by 3400rpm.....but even that figure doesn't do it justice, these things seem to spool from idle, the response is awesome!
No suggestion it will at this stage.
Giving reasonable thought to the topic would lead me to think twin scroll may be difficult on the mixed flow turbine, not without unequal/biased division. In my mind it is a open housing specific turbine.
Am happy for BW to school me, though. It would only be even better I'm sure.
I've found that option on some websites in order to purchase but no official spec sheets outlining things like dimensions, part numbers, model designations to cover but distinguish the 7163 lineup.
Seems like a tight-lipped affair.
Wonder if Geoff would enlighten us.
Edited by gmx
22psi:
25 psi
That sounds good, what would you expect the 0.92 divided to generate? using one of your manifolds.
The new 7163 T4 twinscroll turbo is very impressive, although it is larger than your stated airflow requirements. it is available as 0.85 a/r singlescroll (iwg T25, iwg vband or ewg vband) and the 0.80 twinscroll T4 IWG. 7163 production is going on right now. We are not going to list them on our site until the reservation lists are filled (too many phone calls about them as it is), people on our reservation lists will be getting the turbos first, if you want to put your name down it doesnt cost anything we will contact you once they become available with an option to buy. thanks everyone for your patience still a few weeks away but its happening
if youre interested in the 7163 we will have details at the end of this week, pricing and availability. with regards to your gtx3071 it was on a .63 where our test was .82 a/r (for the sake of comparison to the EFR's .83 a/r)
I would expect the 7163 to have full boost long before 4000rpm. also most of the t4 twinscroll EFR turbos like 7064 or 7670 should also acheive that. The singlescroll might do it but it would be close
No T3 option apparently.
Fair enough, I hope to get mine done in 2 weeks. Im looking around the 380 mark. Thats with a 50mm ex gate but
Be sure to post results, by the way - what are the engine specs, and fuel ... again?
Hi Geoff,
Have you got any details on the TurboSmart IWG? Is it a dual port?
the turbosmart IWG uses very large coil-springs (looks like an EWG inside) and is currently available as single port only. dual port is being shown at PRI next week. im impressed thus far
So what are we thinking then, BW 8374 0.92 IWG on BP98? (using full race manifold)..The turbo looks the gear certainly, but I am just a little bit concerned of possible lagginess coming from twins, I know the engine can handle 2 Bar/ ~29Psi no worries. I only want a legit 400KW ATW and therefore want the best possible drive-ability for this power level. Geoff or Lith, anyone got any ideas?
if you are used to upgraded twins, the twinscroll EFR8374 gives up nothing. For your 400kw target it is easily achieved with conservative tuning and moderate boost. The 0.92 a/r nor the internal WG will present any restriction at this power level. EFR turbos are far from lazy or laggy *as long as its a proper twinscroll divided manifold* and the turbo should be 'on' by 3500rpm, full boost by 3600. this is still my all time favorite single-turbo that ive run on my personal rb26.
:cheers:
Perhaps I missed it, but will the 7163 make it the B2 frame, TST4 production?
the new EFR7163 is a B1 frame only. Borg Warner is also releasing a new 0.80 TS T4 housing, specifically to fit the B1 size hub socket (behind the turbine wheel). this hub socket is much smaller than B2 size, so they are not cross-compatible
Giving reasonable thought to the topic would lead me to think twin scroll may be difficult on the mixed flow turbine, not without unequal/biased division. In my mind it is a open housing specific turbine. Am happy for BW to school me, though. It would only be even better I'm sure.
I initially made the same assumption, until they showed me in the lab that twinscroll absolutely does work with mixed flow! on our 3.5L ecoboost v6 ford engine, the twinscroll 7163 gets 20psi right around 2000rpm! thats just nutty... and hence why im dying to try the 7163 twinscroll on my 2.0L evo in a couple months
Edited by Full-Race Geoff
no official spec sheets outlining things like dimensions, part numbers, model designations to cover but distinguish the 7163 lineup. Seems like a tight-lipped affair. Wonder if Geoff would enlighten us.
the 7163 is borg warner's latest EFR release for 2014. It is based on the B1 frame, so it shares identical outer dimensions (silhouette) with the 6258 and 6758 turbos. Some unique features that set this apart from the other EFR's are that it uses a lightweight alloy bearing housing (watercooling mandatory), mixed flow turbine wheel (MFT) and aggressive compressor wheel blade aero which supports up to 60lb/min max compressor flow rate, with a broad surge margin - biased towards midrange/lowend torque and spool/response.
The 7163's are not yet listed on our site, because demand has been very high and supply is low (BW is shipping slowly, but they are shipping) Details will be listed on F-R.com sometime later this month... after PRI and once BW is on track with production. The (4) turbine housing options and variations of 7163 are:
-T25 inlet/vband outlet IWG 0.85 A/R singlescroll
-Vband inlet/outlet IWG 0.85 A/R singlescroll
-Vband inlet/outlet EWG 0.85 A/R singlescroll (im dying to run 2x on an R35)
-T4 twinscroll IWG 0.80 A/R
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
