-Vband inlet/outlet IWG 0.85 A/R singlescroll
-Vband inlet/outlet EWG 0.85 A/R singlescroll (im dying to run 2x on an R35)
Are these going to be the Tial V-band? IE the Tial GT28-35 size V-band flange?
yes, the inlet flange is the same for these EFR7163 vband housings as for the Tial gt28-30-35 vband housings
When will these become available?
*prepares Mazworx V-band manifold* I knew I'd been saving this for a reason :)
if you are used to upgraded twins, the twinscroll EFR8374 gives up nothing. For your 400kw target it is easily achieved with conservative tuning and moderate boost. The 0.92 a/r nor the internal WG will present any restriction at this power level. EFR turbos are far from lazy or laggy *as long as its a proper twinscroll divided manifold* and the turbo should be 'on' by 3500rpm, full boost by 3600. this is still my all time favorite single-turbo that ive run on my personal rb26.
:cheers:
Since I only get about fullboost by 4000ish with my -5s setup, this mean the 8374 will actually be spooling quicker ? The more I read, the more I'm tempted to do it. It's just al these custom thing that need to be done to fit these on a rb26. I saw raw's manifold didn't require relocation of powersteering, wouldn't a 8374 fit on these manifold ?
Best advice:
You want it done right, use the parts it was designed to go with, go with the Full race kit. Who better than Full race to produce the kit since they were part of the R&D. A badass turbo doesn't go cheap like dinosaur -5 bolt on.
For what you're after you're fine but if you don't mind spending more, the 7163 will be the turbo you want vs the 8374 which is much more power than you want.
Best advice:
I highly doubt you will get 400kw with a RB26 on a 7163, stick with 8374
Edited by Sub Boy32
To be totally honest, I believe my setup could make more power but the -5s are beeing the bottleneck. HOWEVER, who really needs more power when speed limit are 100kmh and your already faster/as fast stock gtr/r8 ?
Am I aiming a certain power range ? Not really... do we all want more ? of course. but if I could have the same power the -5s make with the spool my gt-ss had. I would be a happy man. Geoff's advice was that 7670 was too small on rb26.. hence why I named the 8374.
I don't think he's making 400kw. but I could be wrong.
I don't care about number. everytime you ''brag'' about a number. theres one guy who will bring the '' this X dyno is better than Y dyno'' ''your tuner didnt set his dyno properly'' yada yada. Let just say, Poncam B and -5s , get the idea.
7670 results.
Firstly, I must say that we had boost fall over as you can see we went from 22-17psi. Thats because of the 7 pound spring in the gate.
Secondly, is was a very hot very humid day and engine was heat soaking manifold real bad.
Also the 3 inch exhaust isnt helping. I need 3.5 realisticly.
Otherwise, its an animal. That is tuned on the the following
'Built' 25 (balance, rods, cp's etc etc)
Greddy manifold
Plazmaman inlet
Big cooler
256 poncams
Nismo 555 inj
600+ cc of water meth
caltex 98
and the other supporting goods.
We had a fair bit of wheelspin on the rollers as well. Didnt realise until after though...
Its not coming on at the late 3000's but more the mid 4000's rpms. Around the 3k and under its not real different to the t04z..
What I can say though that the dyno doesnt is the transient boost response. Its f****ng unreal. It pulls unreal right through, and if you break traction its crazy how fast it responds, even between gear shifts its like its supercharged.
Its like a whole new car to drive, but still placid in the cruising rev range.
Not any time soon I plan to do 3.5 exhaust and put in a bigger spring, but not in a hurry.
My tuner believes it should do near 400 with out the wheelspin, bigger spring and exhaust.
Feedback?
Edited by abr33
^^ You really think a 3.5 inch exhaust would make the difference here ? So without the enmormous boost drop and on a dynapack, im pretty sure you would've of got to the 400kw mark and thats with a 7670 on rb25.
Great result ! :)
Just curious is there a reason why you start your run at 3800 ? instead of 2500 for say?
Otherwise, its an animal. ..Its not coming on at the late 3000's but more the mid 4000's rpms. Around the 3k and under its not real different to the t04z..
glad to hear everything is running and you enjoy the setup. a few things to look at:
-This 76mm EFR should come in much faster than the 84mm T04Z, according to the chart: 200tq @4200rpm your spool is a bit later than we are used to seeing (but the run started later than usual). Start by searching for some boost leaks (couplers, leaky IC core, cracked intake manifold, bad TB seals, bad injector oring seats) or possible pre-turbo exhaust leaks .
-wg spring - go slightly stiffer should give a nice bump in low end, 7psi is a soft spring
-i expect 3.5" exhaust would not gain anything at this power level
  • Like 1
How does this WMI much compare to running E85? Decent power, response sounds good but that boost threshold sounds really disappointing... Like to be comparable with a T04Z at low rpm isn't flash, at all. I hope you end up finding a cause and fix as struggle to imagine that as being right.
Sent from my GT-I9505 using Tapatalk
That's all just Off my first impressions too. I know I have a very small leak at the tb as the water was bubbling a little. Not what you'd say to make much change. And don't get me wrong, it's much faster than the z. Just Off boost eg 3k it makes about 8 pound where the z made about 5, its not a problem though. It doesn't feel laggy at all as it speeds up with engine in a way I can't explain. It's going to be dangerous in the rain haha. Once I sort the leak I'll see how it is. I might try get on the air strip for a video of the response?
Overall love it. :)
  • Like 1
Great result ! :)
No idea. Only that run was short all others were from under 3
New page on the FullRace site: http://www.full-race.com/store/turbos/borgwarner-efr/borgwarner-efr-7163-turbo.html
I find it very hard to believe that BW have managed to squeeze a usable 61lb/min out of a 71mm OD compressor, but I would be both silly and hypocritical to say it can't be done because I haven't seen anything like it before and don't know exactly how BW have done things in order to reach that claimed performance.
Very very very interested to see how things go when these start showing up on some cars, if it does meet the claims then this should be a game changer all by itself.
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
