Here's an RB25 result.
Pretty happy with the increase.
EFR 7670 1.05 A/R Twin Scroll
Red = EFR 7670
Blue = HTA 3076
Need stiffer springs in the gates to bring boost on earlier and hold more boost later in the rpm.
7psi springs in EFR vs 14psi spring in HTA
Awesome result, and thanks for sharing - had been meaning to see how you are going with this, and if you'll be at WTAC this year!
Even more jealous than ever, before this BOTH turbos were what were in my head likely to be a couple of the best things you could put on an RB25 road/response car so this is good to see. The slightly laggier to spool but more power per psi thing from the 1.05 EFR were both things I expected to see, but to be honest I didn't expect THAT much of a power difference. Very impressive.
I thought your HTA made more than that, for some reason? And how does it drive, if you have? I'm guessing you won't be feeling the extra little bit of lag the dyno is implying.
  • Like 2
Maybe try a 4 port BSC, should do what you need instead of waiting for a new spring
Even more jealous than ever, before this BOTH turbos were what were in my head likely to be a couple of the best things you could put on an RB25 road/response car so this is good to see. The slightly laggier to spool but more power per psi thing from the EFR were both things I expected to see, but to be honest I didn't expect THAT much of a power difference. Very impressive.
I hope to be at WTAC, only yesterday I was mopping up a huge oil spill under the rear of my car. Although I couldn't see where it came from it was definately diff oil..
Bloody thing, been really good of late. Did a 60sec lap of Wakefield and went under 2min on the long Brabham track at EC recently. All was looking good.
The EFR made heaps more, very happy as I was a little nervous about the change, should be a beast on the track now.
That's on petrol, the HTA was tuned on both 98 and E85.
The EFR will only run 98 as the car is mainly for enduros and short races etc. Fuel economy is important and really the only reason why I changed turbos as I needed more power on 98 to make the car quicker.
Shit. That's a really good result on petrol, for both really. Shows how much better the EFR is on the exhaust side especially!
Again, thanks for sharing - food for thought.
what manifold is the turbo on?
6 Boost - Twin Scroll - Twin Gates
How much more would be in it with stiffer gate springs?
That would be interesting!
Given it's on 98 probably not much. It bleeds down to around 20psi, if it could hold 25psi you could probably add 20-30hp, maybe a touch more ??
Wow, awesome results! Thanks for sharing!!
When you drive it, make sure to report back and let us all know how different if feels on the road.. should beat the crap out of the HTA for transient response.
Edited by Tonba
Jus to confirm; the HTA was T3 open, was it not?
I just want to make sure I'm looking at the thing correctly. Don't want to mislead myself in case this isn't apples and apples.
Yep, that'll be the old 0.82 T3 housing it had - same as Mat's... 445whp/332rwkw (Oz dyno) one of the highest power figures on pump gas on an RB25 I've heard of with that hotside! I'm picking that's where a lot of the extra power came from, the 1.05a/r T4 is going to be helping out a bit with that cake and eat it too business the EFR is doing.
Its not going to be the only part of the puzzle though, very impressive result from the EFR. Makes me sigh, yet again - that I lost patience with Borg Warner sorting themselves out with these things... if they hadn't had those issues I'd probably never have given up on my car and instead been running around with a setup like this :(
Hi guys. I am a bit behind with this thread and apology in advance if it's already mentioned.
I am setting up the boost solenoid setting on the motec and for some reason can't find the specific frequency of the BW boost control solenoid despite some serious search on the net
From what I recall seeing ....very scantly atm since there are so many things on my plate....that it's around 28 Hertz.
Could someone kindly let me know what is the correct setting for this boost control valve?
Thanks in advance.
At least theres a couple of us still winning on 98. My knock threshold seemed to be up around the 27psi mark. Makes the hassle of E85 a lot less appealing than it already was.
.82 open to 1.05 divided; am not too sure much could be attributed to top end power, I think they would lay in a fairly similar area. Though I'd believe the T3 variant of the 7670 would compress the left hand half of the curve a few hundred RPM.
Still noteworthy as it is really winning on power for 98. Am curious what sort of turbine speeds would be seen from a healthy 3L on the T3 open... I may be conjuring something of that spec sooner than expected.
Ah found the answer lol ... 32Hz :)
Lucky you found that. As clued as everyone on here is I highly doubt anyone would have known off the top of their head.
Edited by GTScotT
Have you got yours all fixed up now? Heard about that, sucked to hear :( By your comments, have you got a new power figure now - or you are referring to the old 290ishkw?
I partly think the EFR7670 probably has a bit more turbine, before you even get into the fact that it's got the 1.05a/r TS hotside - but before they reach their limits I've seen a few cars even with similar turbines make more lb for lb on that kind of hotside comparison, even if "all in" the peak numbers don't necessarily end up being as different. I'm guessing that on E85 it may not be so much of a difference, though could be wrong there. I tend to agree on the T3 open likely to come on a bit earlier than the 1.05, not sure if it'll be on before the HTA or not but I'm guessing it'll bring the results a lot closer in spool and power to the HTA - if not equal to or better than in both cases. Would be interesting to see, though tbh the 1.05 seems like a winner.
On the Full-Race site there is a dyno of a Supra with the 1.05a/r housing doing 524whp on petrol: http://www.full-race.com/store/turbos/borgwarner-efr/borgwarner-efr-7670-turbo.html
Finally finished with all of the 96 pages!
Very interesting turbos that BW churned out.
I'm currently in research mode for my next turbo to buy, because my R34 GTT needs a new one.
The one thing I hoped to get answered from this thread:
Can you run the EFR turbos with an old ECU like an Apexi Power FC without fiddling around too much?
My tuner hasn't got his hands on any EFR turbos yet and is a bit reluctant to first try one out in a customer car...
He specifically stated that the EFR turbos were different compared to older turbos in boost control and/or waste gate control and the ECU would need input ports that the Power FC doesn't have.
Can't find any reference to that in this thread nor through googling :(
I do think he knows what he is talking about and has has got extended experience with Borg Warner turbos. The shops owners run 3x S366 on two Supras and a R34 TKR.
Anyone care to clear this up? ;)
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
