GCG were able to also advise turbine speeds over 153,000 rpm could cause failure. They reported quite a few failures of the 9180 used in time attack under extreme conditions.
153,000RPM is nothing for a turbo. your stock turbos probably spin hard then that at full boost. There should be no way of exploding turbine wheel at that point. Might be some welding bits fell out of exhaust manifold or things jammed into the turbine housing.
So after BWs mega hours of testing
you're telling us that they are wrong......
I hope this is the case
I'm just passing on what GCG told me. It's not uncommon for Ti wheels to fail in this way. Borg Warner or not. This is why the limit is posted on the compressor map an they actively support the purchase of a speed sensor and road rage gauge. Ti wheeled turbos are certainly more fussy than their inconel cousins. On closer inspection of my turbine wheel it has porous holes noticeable in the surface which doesn't fill me with confidence in regards to expansion rates.
This whole failure analysis process is about understanding why my turbo failed after 100km to make sure it doesn't happen again. Im not trying to poo poo the product. I've have already bought a replacement 6758.
Matt
Peter, Please understand the max speed will depend entirely on the diameter of the wheels, it doesn't matter who makes the turbo.
560 m/s is turbo mfg's definition of max wheel speed. This is the same across the board for "maximum tip speed" -- Not krpm which does not factor in diameter. 153k rpm is enough to fail most any gt35R or gt40R sized turbo and can only be acheived with a significant boost leak. unfortunately most people do not accurately monitor turbo shaft speed or EMAP which are 2 critical operating parameters for these engines
Mate's EVO with a Garrett reads off 170,000RPM at 18psi. And that thing's through hundreds of tracks days. 153,000RPM can't cause your wheel to explode.
Peter, your friend's Evo has a very small turbo or his speed sensor is setup wrong. There is no reason any aftermarket garrett turbo on evo should be operating at 170k rpm. it would need to have a small turbo with boost leak.
Edited by Full-Race Geoff
Matt
ImageUploadedBySAU Community1427772038.605493.jpg ImageUploadedBySAU Community1427772475.999362.jpg
was referring to old mate petre
post-49288-14279561108357_thumb.jpgpost-49288-14279561336696_thumb.jpgpost-49288-14279563417955_thumb.jpg
post-49288-14279565241856_thumb.jpgpost-49288-14279565804777_thumb.jpgpost-49288-14279566604959_thumb.jpgpost-49288-14279567264545_thumb.jpg
Inspection of the failed EFR shows the turbine most likely was damaged due to a piece of the turbine housing coming loose. Discoloration around the fragment area shows it separated recently. Comparing the turbine housings there is a vast difference in finishing. Also the turbine discharge area has been revised. The newer version is channeled around me the entire turbine outlet which flutes the wastegate gas. The earlier version channel is only 30% of the outlet. I wonder if this was done due to uneven expansion rates..
I'll have a chat to GCG. I feel I may have a case for refund/rebuild.
Matt
  • 3 weeks later...
If ever a found my EFR 83/74 1,05ewg with type-R cam not responsive enought, can i simply swap a 76/70 1,05 EWG in place on the full-race manifold and expect a more responsive rb26 ?
Also, #2, I have a haltech ECU, would you rather keep your profecb2 EBC that act as a boost gauge at the time or use the EFR boost module and buy the boost solenoid to control boost over the haltech ?
I believe going from the 8374 to the 7670 you will
Need to modify the dump pipe slightly as they're not based on the same frame/housings. It will still fit on the manifold but the exhaust will need to be in a slightly different spot. You maybe should have gone the 8374 in the 0.92 IWG.
maybe... but got a good deal on a EWG setup.. and was told the difference between IWG and EWG was approx. 80whp by Full-race. Not ot mention the problem with the IWG tha tneed to be swapped for a turbosmart unit.. i just went ahead with the EWG deal I found..
#1 as long as youre using 1.05 a/r on the 8374 and on the 7670 -- they should drop in place of each other without any changes other than IC piping coupler and intake coupler to suit. I doubt the 8374 will not be responsive enough on RB26, its a really really good combination
#2 Haltech ECU is very good, it can control the EFR 3 port BCSV or the profec solenoid you already have. We just started to carry the 4 port solenoids also, which is an option to consider
I disagree Piggaz, i dont think he will need to change anything on the hotside between these two turbos
Can I still use my greddy profect just to monitor boost reading ? i like the fact the profec fit in the clock compartment and take zero place while a 52mm gauge will take useless space.
Hi Geoff,
For your RB kit with the 6258s is it possible to use an external wastegate on it ? and why did you go with the internal wastegate set up ? was it just for the utilizing the parts that already came with ?
Thanks
Bummer... I asked last page about fititng issue with the Single manifold for R32.. i was told it was better to fit a single stage P/S pump.. Well the problem is not the P/S, it's the A/C.
If I go with a R33/R34 A/C pump, can i still use my r32 crank pulley and simply adjust the belt ( if needed) or i need to change everything.. maybe I should've of went with the Raw manifold that clear everything. :(
  • 1 month later...
I have one, but I am still waiting on my cylinder head and my manifold for my 83/74 .91 AR IWG turbo now from RAW Brokerage.
I will have pumpgas dyno numbers hopefully before summer, but it will be on a BC stroker motor w/ ported head and mild cams.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
