http://www.motoiq.com/MagazineArticles/ID/3886/PageID/9248/PZ-Tuning-660-WHP-Civic.aspx
9174. Any info on this this, Geoff? Is this just a shoehorned 9180 cold side with a 8374 hot side that someone has banged up?
If you put anything smaller than a 9180 on that new motor I will disown you!
  • Like 1
Article says as much. Though unclear whether BW itself created it or some other supplier.
more info + dyno here http://www.motoiq.com/MagazineArticles/ID/3849/PageID/9105/GTA-Road-Atlanta-teamcanada.aspx
Edited by Skepticism
Hi Geoff,
For your RB kit with the 6258s is it possible to use an external wastegate on it ? and why did you go with the internal wastegate set up ? was it just for the utilizing the parts that already came with ?
Thanks
our RB twin turbo kit is designed as IWG only. The kit was designed in this configuration for maximum performance and simplicity. These internal gates work extremely well and if you need a particular boost config the turbosmart IWG's are a good option. Going to an external gate adds complexity and cost due to the dumptube/ewg/flanges/clamps/hardware... This weekend i get to drive a built 2.8L Twin 7163 R34 GTR -looking forward to it ;)
"Reaper" is running a 8374/1.05 on a stock bottom end with step 1 V-Cam.
:thumbsup: 8374 is a lot of fun, I can only imagine with the V-cam
yes the 9174 was initially tested on Sierra Sierra's Time attack evo in the early days. It spools right between 8374 and 9180 and makes power right between 8374 and 9180. It was never released but we've seen through testing it is a good unit and may put into production. The biggest advantage is this turbo has the ability to spin the EFR 91mm compressor wheel to 125k rpm (9180 max speed is 116k rpm)
lol :ban: - in all seriousness, the singles have their place (got one on my car) but twin EFRs are next-level
Pretty keen to hear how the twin 7163 goes Geoff please keep us updated! Wouldn't happen to be able to share a dyno sheet of the above mentioned car?
I have a 7670 with 1.05 rear coming for my stock block evo 9 in a few weeks!
Making my own manifold and plumbing up too. Cant wait to see how it goes!
Edited by Mick_o
Going into my UCF11 Celsior with VVTi 2JZGTE + T56 6 Speed + Haltech Elite 2500 and some e85.. Initially meant to order the 8374 but entered the 9180 in and ordered that instead so I shall see how it goes
Edited by Weapon
the 82mm is a monster turbo and the 87mm turbine wheel in 1.25 a/r works very well. However I prefer twin S300SX to giant single S400 or S500 when targetting really big power numbers. although for a drag car singles are no question easier to package and service, both have their upsides
Have you had much to do with the Tial v-band exhaust housings to suit these turbo's ? Hard to get? Pricey ?
Tial's traditional GT40/42 vband housings will work on BorgWarner Airwerks S300 and S400 turbos, when machined to fit. attached are a couple photos of these.
We helped tial with some of the EFR housings initially, but these EFR housings are different from other turbine housings and do not swap/carry over. It requires all new tooling and investment castings so it will be a bit longer until they are available
nice!! i have wanted to do the same in a UCF20, cool project
  • Like 1
Nice! I have a good friend who asked me about the Tial housings for the S300's.. I'll definitely be showing him that..
Yeah something a little different to the norm to liven the old girl up and have a bit of fun with. Next up probably going to the 8374 with the twin scroll internal gate housing for the Aristo as I am super impressed with the 9180 I got the other day.
  • Like 1
Hi Geoff,
I have recently finished building a twin 7163 setup on a inline 6 (not RB) and we are unfortunately having issues with the turbos shuffling/surging.
Would having the larger comp covers with surge slots alleviate this issue? If so is there some way we can purchase them?
Can you machine the 7064 comp cover to fit the 7163?
Have the twin 7163s on R35 or your RB kit suffered this?
Cheers Blake
dont knock it, if you havent tried it :) that 7163 is a sick little turbo. the fact that it's in a smallish package is just to help make my life easier when fitting twins on an R32 or R35. If that photo of the 7163 was taken next to a 3071R and it doesnt look so tiny but the b2 EFR is a big frame size
By the way, putting a huge diameter inlet ported shroud compressor housing on the 7163 saw zero benefit across the map. the decision was made to keep the package size minimal with 2.5" inlet and 2.0" outlet.
hi blake - I need more information. did you get the turbos from Full-Race, if yes how long ago (specifically are these gen1 or gen2 7163?) What displacement is this engine and what rpm are you experiencing the surge? I would suggest to spend some time on borgwarner's matchbot page and figure out this engine's operating parameters to the best of your ability
Hi Geoff,
Cheers Blake
  • 1 month later...
Posting on behalf of "Reaper".
Stock N1 engine (V spec II nur)
Borgwarner EFR 8374 1.05 AR rear
AI industries surge tank and Holley 1800 dominator pump with Walbro E85 intank pump
Bosch 2200cc injectors
Tial 44mm wastegates
Full Race twin scroll
4" dump into 3.5" kakimoto exhaust
ATS carbon twin clutch
HKS 100mm intercooler
HKS Step 1 V cam (248 @ 8.6mm)
AAF5E4D7-F072-4218-B83D-7D64932E8EAD_zps
Jezzebelle stopped there because of the standard engine.
* Green line is as it was dropped off, Red line was the final result.
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
