http://www.motoiq.com/MagazineArticles/ID/3886/PageID/9248/PZ-Tuning-660-WHP-Civic.aspx
9174. Any info on this this, Geoff? Is this just a shoehorned 9180 cold side with a 8374 hot side that someone has banged up?
If you put anything smaller than a 9180 on that new motor I will disown you!
  • Like 1
Article says as much. Though unclear whether BW itself created it or some other supplier.
more info + dyno here http://www.motoiq.com/MagazineArticles/ID/3849/PageID/9105/GTA-Road-Atlanta-teamcanada.aspx
Edited by Skepticism
Hi Geoff,
For your RB kit with the 6258s is it possible to use an external wastegate on it ? and why did you go with the internal wastegate set up ? was it just for the utilizing the parts that already came with ?
Thanks
our RB twin turbo kit is designed as IWG only. The kit was designed in this configuration for maximum performance and simplicity. These internal gates work extremely well and if you need a particular boost config the turbosmart IWG's are a good option. Going to an external gate adds complexity and cost due to the dumptube/ewg/flanges/clamps/hardware... This weekend i get to drive a built 2.8L Twin 7163 R34 GTR -looking forward to it ;)
"Reaper" is running a 8374/1.05 on a stock bottom end with step 1 V-Cam.
:thumbsup: 8374 is a lot of fun, I can only imagine with the V-cam
yes the 9174 was initially tested on Sierra Sierra's Time attack evo in the early days. It spools right between 8374 and 9180 and makes power right between 8374 and 9180. It was never released but we've seen through testing it is a good unit and may put into production. The biggest advantage is this turbo has the ability to spin the EFR 91mm compressor wheel to 125k rpm (9180 max speed is 116k rpm)
lol :ban: - in all seriousness, the singles have their place (got one on my car) but twin EFRs are next-level
Pretty keen to hear how the twin 7163 goes Geoff please keep us updated! Wouldn't happen to be able to share a dyno sheet of the above mentioned car?
I have a 7670 with 1.05 rear coming for my stock block evo 9 in a few weeks!
Making my own manifold and plumbing up too. Cant wait to see how it goes!
Edited by Mick_o
Going into my UCF11 Celsior with VVTi 2JZGTE + T56 6 Speed + Haltech Elite 2500 and some e85.. Initially meant to order the 8374 but entered the 9180 in and ordered that instead so I shall see how it goes
Edited by Weapon
the 82mm is a monster turbo and the 87mm turbine wheel in 1.25 a/r works very well. However I prefer twin S300SX to giant single S400 or S500 when targetting really big power numbers. although for a drag car singles are no question easier to package and service, both have their upsides
Have you had much to do with the Tial v-band exhaust housings to suit these turbo's ? Hard to get? Pricey ?
Tial's traditional GT40/42 vband housings will work on BorgWarner Airwerks S300 and S400 turbos, when machined to fit. attached are a couple photos of these.
We helped tial with some of the EFR housings initially, but these EFR housings are different from other turbine housings and do not swap/carry over. It requires all new tooling and investment castings so it will be a bit longer until they are available
nice!! i have wanted to do the same in a UCF20, cool project
  • Like 1
Nice! I have a good friend who asked me about the Tial housings for the S300's.. I'll definitely be showing him that..
Yeah something a little different to the norm to liven the old girl up and have a bit of fun with. Next up probably going to the 8374 with the twin scroll internal gate housing for the Aristo as I am super impressed with the 9180 I got the other day.
  • Like 1
Hi Geoff,
I have recently finished building a twin 7163 setup on a inline 6 (not RB) and we are unfortunately having issues with the turbos shuffling/surging.
Would having the larger comp covers with surge slots alleviate this issue? If so is there some way we can purchase them?
Can you machine the 7064 comp cover to fit the 7163?
Have the twin 7163s on R35 or your RB kit suffered this?
Cheers Blake
dont knock it, if you havent tried it :) that 7163 is a sick little turbo. the fact that it's in a smallish package is just to help make my life easier when fitting twins on an R32 or R35. If that photo of the 7163 was taken next to a 3071R and it doesnt look so tiny but the b2 EFR is a big frame size
By the way, putting a huge diameter inlet ported shroud compressor housing on the 7163 saw zero benefit across the map. the decision was made to keep the package size minimal with 2.5" inlet and 2.0" outlet.
hi blake - I need more information. did you get the turbos from Full-Race, if yes how long ago (specifically are these gen1 or gen2 7163?) What displacement is this engine and what rpm are you experiencing the surge? I would suggest to spend some time on borgwarner's matchbot page and figure out this engine's operating parameters to the best of your ability
Hi Geoff,
Cheers Blake
  • 1 month later...
Posting on behalf of "Reaper".
Stock N1 engine (V spec II nur)
Borgwarner EFR 8374 1.05 AR rear
AI industries surge tank and Holley 1800 dominator pump with Walbro E85 intank pump
Bosch 2200cc injectors
Tial 44mm wastegates
Full Race twin scroll
4" dump into 3.5" kakimoto exhaust
ATS carbon twin clutch
HKS 100mm intercooler
HKS Step 1 V cam (248 @ 8.6mm)
AAF5E4D7-F072-4218-B83D-7D64932E8EAD_zps
Jezzebelle stopped there because of the standard engine.
* Green line is as it was dropped off, Red line was the final result.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
