  • Replies 182
I can imagine it would be hard to be a tuner just like its hard to do any job but if I did something in my job that my client wasnt happy with they would ask why too wouldnt they...
oh slap, hey I should of just added a smiley face it was a bit pun from other threads I read, I have no experience with hypergear and I think he does a great job...
and I do appreciate your help, its more confirmation for me tbh Im obviously able to see there is a problem, I wouldnt say 'clearly need' though.
so do you have anything constructive to add or are you just venting?
The way it is written looks very different. I think you should change it as the way it is written is basically defamation of a company.
As others have said crank up the wastegate preload. It should only be roughly $100/hour of dyno time. It should be less than 2 hours.
Also pickup one of those $30 turbotech boost valves. It solved the GT3076 problem the other day.
I would be very tempted to have a cheapy turbotech boost controller handy just in case the PFC boost controller is either playing up or has been setup poorly.
$30 is cheap to rule out a potential problem.
Wastegate pre-load is still the most likely issue that needs to be checked.
I just swapped a GT-RS for a 2835ProS on the Stagea and it made 262rwkw at 16psi (bleeding to 15psi) and it was all in pretty much around 3300rpm (from memory). I know there is more average power to be had with fine tuning light, light/medium load but the headline number is pretty consistent with other results.
You will sort it out.
  • 4 weeks later...
Finally got the car back in for another tune with adjustment made to the wastegate... now making 290rwkw, I'll post the dyno sheet once I pick them up...
this time the dyno print should have rpm, boost & afr for a better overview...
Thats fantastic news mate! Well done. Awesome peak power figure and knowing the turbo it will have a very strong mid range.
Just concretes my opinion that these are the best turbo for a stockish RB25 engine.
Well all the reading and research lead me to believe this was the best choice turbo for response vs power, the tuner believes the turbo is too small, but maybe he thinks Im chasing power beyond the 2835s range, I would of been happy with 275-285rwkw tbh, which I thought the turbo was well able to do, much less and it would be in gtrs rhelms really wouldnt it...
I cant wait to post dyno sheets and see what people think... Im eager to see afr's myself
the .82 rear is optioned for the 1JZ as well.
I've just got my HKS GT2835 KAI kit, so I'm interested to see the difference in this over the Pro S. Supposed to be the new version of the Pro S but I cant find much info on it, other then it makes a couple of KW more at the cost of some torque? But its still a bit sketchy anyway lol.
Glad to see you got yours sorted mate. Will be helpful if something similar happens to me when my tune is started
Guys the 2835 Pro S kit for the RB25 definitely comes with the 0.68 exhaust housing by default:
http://cgi.ebay.com.au/HKS-Turbo-Kit-GT283...=item20b4f48ef8
The 0.68 is how they get the awesome response and mid range, but it still seems to be big enough to flow 280-290rwkw on 98, which is enough for most people on stock rb25s.
If someone can repair turbos this could be a great buy:
http://cgi.ebay.com.au/R33-R34-RB20-RB25-G...=item19c1223b3b
Indeed it is a good turbo mate, HKS back cut the wheel so flow characteristics are anyones guess.. HKS know what they are doing tho, that turbo is GUN.
Numbers are one thing, but seeing on road results from a 2835 is totally another league.
i musta got the optioned one as i have an 0.82 rear on my Pro S kit sitting on my rb22
awesome... def waiting to see the graph.. +1 great turbo's and good results
Thats strange I thought the Pro S had either a 0.68 or 0.87 exhaust housing??
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
