Yes bang for buck with this 2835 KAI could be OK . Provided HKS have just machined out their "T3" flanged 0.64 A/R GT28 turbine housing this opens up a few more doors if say you have a T3 flanged GTRS .
If think about it the GTRS already has a port shrouded comp housing on the cold side and it wouldn't be terribly hard to get a cropped GT30 turbine fitted to its cartridge . Again provided the KAI uses the same turbine housing as a GTRS should be able to be machined out for the larger cropped GT30 turbine and you end up with a 2835 KAI but with a 52 trim 71.1mm compressor .
I'll have to check some pics and specs because there is a remote possibility that the basic comp housing used on the 2835KAI is same/similar to the GTRS .
Simple effective upgrade for those wanting a tad more from a GTRS ? A bit less turbine inlet pressure anyway .
A .
  • Replies 182
Keeping these points in mind, a common fault in tuning is setting a high gain to acheive target boost as quickly as possible, yet have boost drop off in the higher RPM. Obviously based on the above the best way to tune would be to start with a low gain and work your way towards target boost by upping the duty cycle.
How is gaining up to 50hp through the midrange and maybe losing 5-10hp top end a fault?
In the powerFC boost control all you can change is boost pressure and duty cycle
so to bring boost on asap would I increase the duty cycle or lower it?
and will this change the final boost pressure?
I think the FC boost control kit has boost and gain? Or it might be boost and duty?
I can't remember, all I know is that the number that is usually 255 when you first enter a boost setting changes over time so I figured it would be gain that ou adjust going on the explanation given a few posts back but it could be duty, been to long since I played with it lol. But that's good info. I now understand what gain and duty do now
Should make it easier when I go to setup the KAI
I've found when playing with it, adjusting the duty or gain, whichever it is, will change the boost you get. I think with a low setting I had it hit about 8psi then start creeping up. But again it's been a while. I know it hit a certain boost then creeped up or down from there but so playing with it to much will change your boost
  • 6 months later...
Gday Cal been reading up about your 2835 Kai hope you have some good luck getting it right id like to know how u go with it mate cos im getting the same kit through streeter its due this time next month. Id like to know what kinda figures you make when you get it dyno tuned mate hopefully its something simple i cant imagine that HKS could of gone too far wrong with this kit considering how good the Pro S was for the RB25s Please keep us posted on what you come up with mate
CHEERS
Mick
No i havent ordered it yet and yes i can see its not looking good at this stage for the Kai kit!
Not compared to the Pro S!
Im keeping my eyes peeled in here to see what the outcome is with this drama with the power figures.
i maybe have too much faith in HKS thinking that they couldnt of gone that wrong with the Pro S replacement cause the pro s was a monster!
I didn't make the same headline numbers as some other people here at SAU with the ProS but I put this down to the variation in car setup, dyno, tuners and the lack of desire to wring the neck of the turbo to make a peak power number.
I think the kai will prove to be a good bit of gear when we see more results.
Not sure what most issue are about having the big top end number, it should be able drive-ability on the street, well it is for me...
My KAI gets me to over 400Nm before 3500RPM and max is up over 450Nm by 4500RPM.... also my power line builds faster that my stock turbo did and does not die off until redline... power is 350Hp up around 6300RPM...
most drive-able 350Hp car i have driven... i even save fuel now as i dont need to drive as hard to get some boost as before....
as said i think too many look for the big end power number but forget about driving under 3500RPM on the street...
just my 2cents after having this turbo on my car... still need my tune to be touched up as well which should see it a bit smoother and maybe slightly better numbers.
89CAL,
NISMO fuel pump
800CC Power Ent. Inj.
Z32
Power FC
Blitz EBC
genreric FMIC
3" zorst come from Japan, bellmouth dump, and some hi-flow cat brought over 4 years ago so can't remember brand
stock AirBox with no cover just a mech grill on filter...
nothing else except a new clutch and a healthy engine according to the tuner.
Mick_o,
yeah i am very happy with this for on the street as i said i get boost better than my stock turbo and am actually using less rev's to drive as the car feels a lot more lively now....
I have a very similar setup.
Nismo 555cc injectors and a K&N pod being the only notable differences.
What AFR and what sort of timing are you running around the top end (if you have that information handy)
Sorry for that i am not too sure.... i would have to ask my tunner next time i see him so i dont give you mis-leading info...
Not a problem
Having a copy of the tune to compare would be great, but I'm not going to ask for that as I know the answer I/You will get from the tuner lol.....
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
