fixed exhaust leak and (Scotty! :domokun: ) welded up a front pipe which included my flex join and cat.
mmm, welcome back boost :laugh:
Glad you're happy buddy, cant have a fellow Stagea owner getting around with no boost. :(
Picked up my freshly rebuilt exedy 5puck clutch today
and got to have a geez under a 35gtr that was up on a hoist in the shop
wat a gorgeous piece of Japanese engineering!
Eww, my car went in today to have the puck clutch removed. It's a PITA to drive around in traffic with - I've got no idea what Adelaide traffic is like, but here in Sydney you can find yourself doing 15-20km/h, stop-start, on the FREEWAY at times.
Spigot bearing is making a hell of a noise when cold anyway, so I'm killing (at least) two birds with one stone!
Really nick? Is it heavy or just super bitey?
And is your clutch master vacuum assisted?
I've got a s14 master and pedal installed already so it's not vacuum
traffic here's pretty easy,plus the times I go to work every other sucker is already working so it's not too bad
These have actually been on the car for a couple of weeks now, but I haven't had time to take any photo's, and it's been raining most days for the last couple weeks here.
Using my iphone again, cause i dont have a real camera :D
18x9 +18, 235/40 Toyo Proxes 4
Needs to be about an inch lower all round I think, and spaced out a little at the front. I also need to get a set of centre caps for the rims.
Tried replying to this last night, but the forums were down...
It's actually bitey AND heavy. I can deal with the heaviness (even though I'm a skinny mofo), but like I said, with Sydney traffic the bite is a PITA. It's either in or out, and sometimes the car shakes REALLY badly as you try and release the clutch to move along slowly.
Nope, it's not assisted.
Here's a link to the sales threads that lead to me buying my car (I bought it from Argo just under 5 yrs ago): http://www.skylinesaustralia.com/forums/se...mp;highlite=%2B
Here's a link to his posts in the manual conversion thread (from post #63 onwards) - my car is the dark green one: http://www.skylinesaustralia.com/forums/in...t&p=1545409
^^ x2 Nick
Our new organic clutch makes the car a much more pleasant drive in traffic.
I'm soooo looking forward to having my car back so I can experience that for myself! Hopefully tomorrow, Andrew. The clutch is in, it was on the dyno this arvo when I called the workshop.
Just won a RHS Silver mirror for my S2 on Import Monster.
My RHS mirror got badly scratched on the garage wall at home, far too scratched to buff it out with cutting compound. Hopefully the air freight will get it here before the 21st of this month.
Looks hot! :whistling:
they look awesome brian! just a 20mm spacer on the front, a little lower and you'll be set
Thanks fellas :happy:
Yeah Mike, just needs a little bit more work and I'll be happy with it. Although I probably won't be able to go as low as I would like, due to the car being a daily - and I wouldn't be able to get it out of my driveway :laugh:
i bought a piece of pipe :)
its used but for $100 you can't go wrong
will get a new turbo-manifold gasket and turbo outlet gasket and some new tie rod ends and an alignment also
nearing the end of the cheap and easy mods now tho :D
Edited by pipster11
brian, looks awesome.
found a brake fluid leak in the Wilwood line setup, fixed. finally. 324mm wilwood superlite goodness.
doing a service on her at the moment, awaiting 4x 15mm thick bolt-on wheel spacers (needs 10mm to comfortably clear the calipers due to bracket setup
Loving my single plate organic from extreme. The stag is the first manual car (converted on the weekend) and Ive been driving in city traffic and finding it fine.
I personally kept away from Extreme clutches when I did my conversion. Ended up with a Nismo kit inc lightened Nismo flywheel which I sent all the kit to ACS for machining. Strong pedal feel, but very forgiving 1200kg kit. Not 'off or on' like most. I've had Extreme clutches in past cars and I haven't been impressed.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
