I'm sure you'll get whatever you agreed on. I thought scotty might have kept the sump for the VQ35 conversion. Whats the plan, just put another stock back in, or toughen it up a little?
stocky with all my bit's.......TOW it down to VIC.....put it on a dyno and that's it! Then finish off the rest of the car!
New hi flow cat and 3" front pipe going on today to marry up to dump pipe and Legalis exhaust. No more compliance cat & stock pipe! :thumbsup: Powahhhh!
Good stuff Dale! In a couple of weeks you will not even remember how bad the stock lag was :)
New hi flow cat and 3" front pipe going on today to marry up to dump pipe and Legalis exhaust. No more compliance cat & stock pipe! :) Powahhhh!
What front pipe did you get??
I need to do front, cat and dump soon and then hit the drags again :D
Just purchased some 19" GTR LM4 nismo rims for lots of money. and a HDI kit from Hybrid Power international.
add tyres.. almost 5k on rims and an intercooler.
"hides the reciepts from the mrs"
I need to do front, cat and dump soon and then hit the drags again :(
My mechanic is putting it together today, I'm picking it up tomorrow. Pics to follow.
Nice Rims mate, saw them on IM for a little while and was tempted, but couldn't part with the cash! Need picks for sure once their on.
As for the Mrs part- good luck there! :(
Haha my mate suggested i get 5 sets of different locking nuts and just having all different locking nuts on them.
Be left on bricks without them in the city ;)
just started from scratch with the gizzmo EBC. it was boost cutting like a dog on the freeway if i planted it in 4th. the gizzmo was display 1.03 which i stupidly assumed was 10psi or there abouts - given that it was untouched from when i picked it up from previous owner. i was just blaming the boost cut on spiking due to the cold weather. turns out it was reading in BAR and at 1.03 its actually closer to 15psi! no wonder it was throwing out fuel like a BP oil rig, and boost cutting. also not a good idea to run 15psi on stock wheel turbo as far as i'm aware?!
set the gains back to zero and wound the boost back to stock and went from there. now holding a steady 12psi and boosting so much more strongly to red line. i dont think the car was even getting into VCT before boost cutting before!! pretty happy! in defence of previous owner, it was probably setup for tune with the greddy emanage, but given that is unplugged for now i'm happy with my settings.
What settings did you arrive at, duty, gain and spike?
already have that.
Won the motor last night.....now I just have to get it here! Waiting game begins!
Can I borrow your turbo while its all out! I hear these things can seize up if they don't get frequent use :P
i would have to double check, but from memory the duty is at 40, gain i started at 0 and by testing doing 4th gear pulls and then quickly stabbing the throttle into 5th, it was hitting target boost of 12.4 with gain at 30, so i'll leave it there. spike, i have not touched.
if you need help setting one up i found a very helpful and straightforward thread. the actual manual from gizzmo is dribble. i read it 3 times cover to cover and still couldnt work it out!
car pulls a lot more cleanly now. probably not going any harder, but the fact that i can rev it out rather than have it cut at 5k is a plus!
Edited by SMOKEYC34
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
