Just (very briefly) drove mine with the revalved Bilsteins in the front: 1000000% improvement, but still a little work to do: bump stops still need to be replaced with slimmer items: the old ones were all but destroyed when the shock failed :)
Pretty impressed so far: hoping to have the car back mid next week, handling like it should (and used to)...
What are the offsets PetroDola?
Are they rolling or flaring the guards? The fronts are already "rolled" from the factory, the rears can be rolled.
Is yours a RS? let me know the offset and I can work out exactly how far out from the factory guards they will sit, or if they will foul the front control arm.
Ben
mines actually an RX the one below in my pic is the car in question.
I believe theyll be rolling the gaurds i know the fronts are quite rolled already but the rears will need doing. is the offset is 9.5?
Impulse by at jb hifi
cadence x1 sub package - 300wrms sub, ported box for the sub and 600w amp
$250 :D
now i can take the bass load off the poor 6" door speakers :D
thats the width. It should be stamped somewhere on the back of the wheels hub or spokes. You may also have a sticker on the inside of the rim.
Should look something like 19 x 9.5J +35 etc. 19 being the rim diameter, 9.5J being the width and a + or - number being the offset. Looking at the pics of your rims you would have a positive offset on those, probably around +30 or more. If its higher than +35 you will need to run spacers on the front to clear the front control arm, if its lower than +30 you will need to roll your guards.
So basically it will be perfect at 9.5J + 35 to +30 and you wont have to do anything other than fit tyres!
Edited by bbenny
Hey benny , its 19x9.5 +30 offset
i take it thatyll suit ok?
Thats awesome!
You shouldnt have to roll anything, Just be careful on tyre size, a 245 or 255? should be sweet. If you go something too wide then they will scrub the guards.
but +30 will look sweet! cant wait to see pics when they are on.
Edited by bbenny
Dont you hate it when people fake to go and the stop, instead of merging...........
Oh crap, dude... How bad? looks like the intercooler has had it, aside from the obvious panel damage.... :)
Made an executive decision to trade in the Alpine pre-boxed R-type subs I installed late last year, and permanently mould in the Alpine S-types I have sitting here into a sealed enclosure. I have no idea what I was thinking when I bought the R-types: ported subs are not my thing, but the ability to remove them for track-day antics was appealing.
Since I broke my back, track days are now off the table, so I may as well go with a SQ setup, which is what the rest of the audio system is geared towards... I figure using the subs I already have sitting here will save me a heap of money over the "buy a pair of X-type 12"s" option...
Very much hanging out to get the old girl back witht the front suspension sorted: a drive in a mate's '05 STi reminded me of how the barge should feel on the road, and I believe there is still a way to go...
achieved a bit for the weekend:
- fitted PIVOT speed meter and PIVOT shift lamp
- fitted red LEDs to the dash - now all interior lights are red
- sprayed rain gaurds gloss black and fitted up
- took back surface rust on rotors and sprayed them black with VHT caliper paint
- put on some hubcentric rings, has got rid of vibration at 100km/h
- used glassylite on the UV affected headlights (these things were shot, so yellow that i was trying to source replacements but this glassylite stuff has took them back to brand new - best 40 bucks i've spent on the car)
i have a list of 'to do' stuff, so it's getting shorter each weekend - but the more time i spend in and around the car, the more i find! its tough being OCD!!!
link to glassylite please
im getting sick of polishing them
fitted my sub on the weekend, good to have a ballenced stereo once again, just need to fiddle with the settings some more
edit, also painted the rear brakes in 3m blue caliper paint (same as the fronts) and fitted them
should have my speed bleeders soon and hopefully a firm pedal all the time soon after that :(
Edited by pipster11
Picked mine up again prematurely (so it's still got a bit of suspension work to do), because I managed to trash the front bar on the beemer yesterday: I mean, who thought it was a good idea to put boulders on each side of their driveway, right at the gutter end, where they're impossible to see?!
http://www.glassylite.net.au/
the trick is the 'nano sealant' - but just be careful with your quanitities, they give you SFA in the kit, so you need to make it all last.
hey mate i'd be interested to see ur sub setup, i did some measuring today and was left scratching my head.....
This is the current setup, but as stated, is subject to change completely in the near future...
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
