got a new turbo to install in my car.... :P
what turbo!?
eyes andy suspiciously ... you havent been to jetwrecks have you ? ;)
argh i got delayed again with my suspension and tyres ..not till wednesday now *sad face*
also what difference did the plenum spacer make Dunc - i should probably invest in one of those and leave it on the shelf for two months also :P
I didnt notice the hugest difference with the fmic on a stock turbo.. in fact during the day a slight bit of lag , but a definate improvement at night.
Edited by PetroDola
At the moment, just a lighter wallet - could be because its sitting on my shelf next to me still :P
lol sorry dunc .. same boat as me ,
daleo .. you said it made a good difference yeah? :P
and someone here is making these who is it again.. and is there any left ?
Can i get one pls :P
Edited by PetroDola
daleo .. you said it made a good difference yeah? :)
Can i get one pls ;)
Yeah, bucketloads more torque in the midrange, there's heaps more with my new exhaust, so this is just the cherry, on the icing, on the cake :P . Only had about 40km of diving so far, I'll be driving to work tonight; that'll be a better test.
Jetwreck's your man, but I don't know if he has any left :P .
Cool thanks .. hope hes got some left :S
yeah the dump and full exhaust mod in one go was the biggest improvement my car has seen in performance thus far.
Went to start mine today - it's absolutely DEAD! The fuel pump wouldn't prime, and the alarm/immobiliser wouldn't even turn off.
The battery is fine, but there must be a major issue with the alarm or something. I drove it on Saturday night, it started fine when I was leaving home, but would barely crank when I went to leave my cousin's to come home again. :) Hmmm, if tomorrow is the same (weirder things have happened), it's time to call Unigroup to see if there's a mobile sparky they can recommend.
what turbo!?
eyes andy suspiciously ... you havent been to jetwrecks have you ? :)
He wouldn't let me near his turbo and yours is a long way away...
I had MY spare turbo rebuilt with a Sierra Stage 1 kit..
It will be interesting to see the difference it makes.
PM sent
Edited by Jetwreck
Took the front guard inner lining off to run some wires on the 25G. Down the bottom of the guard back towards the A pillar
was chock full of wet mud, so today cleaned out both sides. There was a good double handfull of mud in both sides that were making a very nice rust inducing enviroment. Had done the RS a couple of years ago.
test fitted my wheels! (18 x 9.5 +20) seem to have heaps of clearance atm as i have bugger all camber dialed in, i may end up running a 5mm slip on on the front to bring them out a bit.
ps. yes there rotas bring on the hate! i couldn't resist them at $999 a set with hub rings and a full set of aftermaket lock nuts.
Looks tough mate. I like it. Do Rotas just get hated on because theyre not JDM, or are they 'considerably' inferior quality? (not being a dick/trolling)
just a few...
and my personal favourite - the before and after track day photos
seen them all mate really doesn't concern me, believe me its an informed decision it is a daily only car but if they do break I will be the first to post them up. For the same sizes from rays 3-4 grand, just not worth it on a daily.
Edited by horrace
TBH a bit of both, they were shit back in the day, all those pics mike posted are old but people have long memories, there was a guy here on sau recently whos spoke cracked but he was tracking an R35 on full slicks obviously my car is a ton lighter and wont be tracked with slicks.
Saw that in the SA Wasteland thread, Nightcrawler had a small spat about it :)
Yeah you guys gotta get your facts straight - they were on an R35GTR doing insane lap times for 6 months, then while the brakes/wheels were red hot from many very hard laps he went through a BIG ice cold puddle and one spoke cracked. Any alloy if you heat it up enough and then dump it in freezing cold water will crack. It is not a reason to stay away from Rota's at all, but rather a hefty endorsement that they can take all that punishment.
you'll be right for daily driving i'd say.
a lot of them were circuit racing incidents - plenty of load put on the wheels
there was actually a member on here that stress fractured the rotas he decided to use as track wheels on his r35
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
