hmm picked up my BC coilovers, greddy boost controller, HDi FMIC arrived at the office!!
come on nismo products from japan!
A busy night in the garage tonight? :P Pics to follow I hope!
haha busy indeed!
tell us if you notice a difference with HDi FMIC .. i actually noticed more lag in the short end because of the stock turbo. but pickup in the middle range top end when it was cold at night (bearing in mind qld winter is 25C)
hopefully that will change with the hiflow.
got some tuning nuts today and replaced the stocky nuts with all 20 of the tuning nuts.
Should be a good deterrent for anyone attempting to steal the rims as theyll need to get all 20 off without rounding the nut and that wont be easy.
and ordered the centrecaps from rays.. $200.. (rip job)
Can park out front without being overly paranoid now!
Edited by PetroDola
Are they the Taleb tyres ones?
I bought a set, finish was nice, but I ended up running at tap down them as the threads were fairly gritty. Check them before you fit them.
hi duncan , not sure what brand they are , i got my tyre friend to source them for me from mullins wheels in SA (the bag had no brand names), but they were really good nice threads and clean.
i needed quite small ones for the key not to scrape the rim as its really narrow
Edited by PetroDola
haha im not going to install till the brake rotors arrive, then ill do brakes and suspension at once to save wheel removal time
i wish i could have done it tonight, had photo comp to go to instead
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
