Funny noises coming from the front of my car, so I think some coil overs might be needed (either that or some ball joints/bushes are STUFFED) :rolleyes:
Sounds like a piece of gravel is in one of the shocks rubbing up and down as I go over bumps and corners.
Anyone got some coil overs they want to sell :D
I think i'm on my way to around 500K's to 70L (14L/100K)!!!
just get a set of BC coilovers from justjap. $1300 later (free delivery i think) and youll have fully adjustable suspension
but check bushes etc as if they are worn, youll probably make it worse with new suspension
Like this one?
Lol yeh like that one!.. smart ass haha
yup wicked economy!!
it does 0L/100mm :P
congrats on the emanage! i should really install mine one day. oh so many things still to install, and so little time :(
hahah
Thanks man!
but then you could confuse the issue more and introduce light penetration to the equation, as a higher kelvin rating increases the spectrum as well, which leads to an increase visibility, and difusion across a broad range of conditions (rain, fog etc etc)
Bought me an eManage Ultimate today with a universal harness for $676.00 Aud directly from Japan with free shipping.
oh.. its BRAND SPANKING NEW :D
Like this one?
* yawn *
Where's the originality guys? :P
fck all this hid bs. light penetration. lol. you should try and get out more dale. You be getn pwned in the wasteland by boz mang. i think he wants to buy teh fury off you.
I got one of those too... :cheers: Plus the Profec B boost controller. :thumbsup:
Just need the time and funds for a road trip.
Geeze, your car is going to be essentially a greddy showroom :P
/begin rant:
My first experience importing a Jap import has not been nice. I'm fixing every bloody thing on it. Doesn't anyone maintain their car anymore FFS?
Spark plugs were stuffed, I think the shocks are stuffed (pretty much a given though) or a ball joint is stuffed, but what really gets me is the STUPID bloody compliance place that did the RWC, DIDN'T FIND THIS OUT! I would've thought they had to check this out as it is a safety issue. Even if as part of the inspection they would say "you'd better change this soon - do you want us to do it??"
I don't even think they changed the oil...:angry:
/end rant.:rant:
PPS -eat shit Mundine. lol
the MOUTH IS NOT A BOXER just a wantbe ,want`s to try to be someone so that he could think he`s liked :whistling:
Mundine vs Woods
^^^ mama said knock you out. LOLburn khunt. he's a brawler and a farkn animal IMO. WTF would you know about boxing chuckie?
BTW I need your spare 350z rims mang- pronto. :thumbsup:
Edited by dirtyRS4
lad i went to school with was british school boy champ ,& as kid we watched all boxing on tv , used to love watch Don Curry ,you might be have seen him in 1980`s lol
