change is both inevtiable and good.
I guess I can't talk about what I did to my stagea today in this thread tho.
Change is only good when it fixes the issue. Should have deleted the old chilli thread in my opinion but I guess that doesn't count only being a paid up member...
What was the issue anyway? I see more crap spoken in every other forum, especially the forced and na ones and there is never anything done there, squeaky wheel ey?
I think you could get away with it, the subtitle of this thread states "But you can talk about other stuff too".. What you did to your Stagea today falls into that catagory, so by all means - go at it :P
its a good philosophy to live by. one of mine is, dont shit in your own nest. lol
hows the sump adaptor issue going with proengines?
not going anywhere with them....but it is off being milled this week. not impossible that I will get it back for xmas again. funnily enough i already have a motor to build next week for the race car
may as well tell everyone. yeah i did
a few things to note:
dont ask me how much i paid
dont ask for parts, ill put up a FS post with everything available. If i get a PM from you, you get nothing.
dont assume its yours unless youve paid for it.
thank you :)
gis all ur good bits ;d
*hitches bisbees wreck to the back of the fourby and drags it from zei20I's driveway in the middle of the night*
:ph34r: :ph34r:
Edited by PetroDola
For real. i would of been hella pissed off with proengines. Are you taking legal action? So that must be your track car in your avatar. got a mate deciding on turbos for his atm, probly a pair of 2560R-5's. Of course you must of heard about Powerchip. lmfao
lol -5s, I wish. Its a production car so has to run standard n1 turbos.
unfortunately for me I have a much bigger problem than proengines to take on atm. I'm just getting that one fixed. Hills Motorsport have already pulled the motor, machined the plate and have lined up some new bearings.
:ph34r: :ph34r:
hahah you wish! its a long drive from my place to yours
speaking of which, i have only seen 2 C34s up here and no M35s. sucks to be in surfers. i was hoping to see one on the highway today up to movie world.
are you in town ?
thats only 45 minutes away from my place.
bah shouldve told me.. i wouldve cancelled my appointment and come and visited yah earlier!
Edited by PetroDola
You can.... But no yelling!!!...lol :P
dont worry about chuckie. his bark is bigger than his bite. hows the dads GIO group A car going, if i have that correct?
:O
what did you guys do to our recipe thread?
Ask duncan. lolz
and those bigger problems are race car related i assume. deadlines to meet close to race day? it's good to hear the stagea is getn sorted.
Edited by dirtyRS4
went thought the BusTech factory in QLD today. my wifes cousins own it and surfside buses. awesome to see how a bus is built and all the engineering put into it!
they were churning out 1 bus a day from the factory in the last year.
today i hopped on a sydney government bus that was almost finished, i felt good because i didnt have to pay to get on it :P
Can someone FAST a part number for me? :)
For lack of a better description, Im after the tensioning pulley (or pulley bearing) for the aircon/accessories belt. Mines making 'death noises' :/
i did mine the other month. dont have a part number, but cost me $150 for both belts, i was told take the belt off and get someone to drive you to repco(or similar) and they can match the belt for a fraction of the cost.
EDIT
wait..
Scrap that i just read it! lol
Edited by AaronNM35
Do you mean this (red) one Dunc?
Your just lucky it was on time, and didn't drive straight past you >_<
Once it gets across the border, there is no hope...:dry:
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
