This is how I look at it.
You sleeping away quiet peacefully, dreaming good stuff- like boost controllers, Digital TV conversions, and maybe even some Transgo shift kits.
All of a sudden your awaken by two Tomcats- making that terrible noise, sounds like they're fighting just outside your window!pinch.gif
Black v Orange- you know its going to be on! Don't watch the whole thing, its a waste of time....
CAT FIGHT!
Edited by PN-Mad
V8 nummers.....never owned a turbo until the last car!
And that my friend is a unique car.
Ps. Tangles....Aaron and I are just mucking around!....nothing malice we actually talk outside sau! We were just missing the wa guys! :P
P.s.s he does have a bitch slap coming to him though when I get down to vic next month!...lolz
Err, Craig; I'm not an expert or anything; but I'm pretty sure that first picture is a fridge...:whistling:
Just sayin'
Says the man driving a hearse! Shit that's me too!
Hey Alex, found this and thought you'd need one (as will my mate) and at that price....
http://www.ebay.com....#ht_7444wt_1163
that looks alright aye........ show us pic's and info once u've mounted it, are you going to make it plumb back also ?
my stock BOV farts so if this is a good option i might join ya's
I'll be waiting you 10kg toothpick!
Had a fridge magnet on the firewall...
ahaha so much win
LOL @ the fridge magnet "Polarizer."
The only thing it polarized was opinions: Brocky's, and everyone else's.
hey don't hassle my Polarizer......it did something....apparently!
Edited by Jetwreck
how does that even make sense?
talk about a massive fail.
So now that Rally Victoria is only next weekend, anyone going to have a look?
I'm flying over around Thursday night I think, coming back Sunday after checking out the rally stages for next year's Rally Calder.
And... who's doing Movember around here?
I've started, got a work team. If you want to donate to the awesomeness that will be my perverted Movember Mo, go here: http://mobro.co/bigkevracer
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
