Is it just me or alot of M35 owners are working in IT? Big assumption I know...
They must be since so many are online during work days. I'm sort of there as well (own a boutique ISP/phone company) but not an IT geek as such.
Why selling? You talked about it before, but why now?
All I remember of your mods is you're running Scotts old setup with ~600cc injectors, gas injection and silk roads.
I guess at the end of the day your car is only worth what people are willing to pay... Might get more if you put it back to stock and sell the parts?
OK here's the list
600cc (or was it 610?) Deka's...
Scott's hi-flowed turbo (by ATP I think?)
Plenum Spacer
HDi GT2 Intercooler
Scott's custom intake pipe
Scott's custom dump pipe+high flow cat
Fujitsubo Legalis R exhaust
Whiteline heavy duty swaybars (F+R)
Silkroads RM/W8 coilovers (less then 6 months old)
Greddy Emanage Ultimate + MAP sensor
Greddy ProfecB II EBC
AEM UEGO Wideband
4 x Kumho Ku31's (about 6 months old)
Stoptech braided brake lines
350z Brembos w/ RDA slotted rotors + QFM HPX pads (fitted in May)
JTG Liquid injected LPG
Asuka TV tuner/media player w/stock Nissan pop up display (Xanavi translation done already)
Nismo radiator cap and oil filler cap (w00t!)
Can't think of anything else...for now.
Tuned for both E85 and LPG. Made 270+ awkw on E85 and 250 awkw on LPG (I'm in the process ot fitting larger gas jets on to see if I can make more on LPG)
Can't really part it out unless I put a stock turbo back on...which I don't have...nor can I be bothered paying for...
Edited by ironpaw
OK here's the list
Plenum Spacer
HDi GT2 Intercooler
AEM UEGO Wideband
I'll give you $3.00, cash, final offer!
Dunc has the Kenstyle, but I think thats only because it was on the car when he bought it.
I'm really happy with the factory Aero kit. I don't think it needs anything else (except a wing, which mine didn't have until I added the Nismo wing).
Freeway Dolphin do kits too.
Anyway, back on topic, why the sale?
Has anyone in Australia kitted out their M35 yet?
I know Dunc has the Kenstyle, but what about everyone else? Most people are pretty happy with how they look from factory?
I have a full Impul kit, but like Dunc it came like that :)
dont sell Jethro.. you'll regret it!
Spoken like someone living with regret ??? BTW, how's it going mate?
I wonder if it's a Melbourne thing? If Scotty announces he's selling, the whole M35 world will implode... tear in T/S continuim & all that
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
