Ever come across some car on the net that made you uncontrollably giggle like a little school girl...?
I had that experience tonight at work. Was surfing along, quiet as at work... then BAM!w00t.gif
Rocky Auto S30 with dry carbon panels, a RB30D (yep, 3 litre, with a RB26 head, and 3 duel throat CARBS!)
Now, I've seen Rocky auto stuff featured before, but it hasn't done much for me in the past. Anyways, the car is currently FOR SALE for about 13 million JPY. So if any of you buggers picked up the new years lottery... buy this...NOW!thumbsup.gif
http://www.modified....-z/viewall.html
Edited by PN-Mad
I mean, having to wait for one or two sets of lights.
Blows my commute out from 40 mins to 50 mins. Total bollocks.
Thats completely unreasonable. Id be writing letters if I were you.
Rush hour in Adelaide...
1000km run-in service & dynotune on Friday.
Forged bottom end, ported head with Tomei cams, gt3076 highflow, S15 450cc injectors, chipped ecu + tuneable piggyback ---- what boost should I have it tuned to?
I believe the ATS Gt3076iw BB turbo losses efficiency around 21psi.
I'm thinking 18psi should be fine, allowing spikes to 20psi (if that happens).
Don't want to stress the engine tooooo much; might just settle for between 1.25-1.33bar I guess.
Ideally the tuner will just keep ramping it up until there is no return for the extra boost and then set it at the figure thats still giving benefit. Hope you get to keep the car although to be honest they are not cheap to run - I am spending $100 - $120 a week on petrol alone!
True. To keep costs down im thinking tho im best to say X-psi tune thanks. Yeh stuff it, I'll tell them tune between 1.25 & 1.3bar thanks very much, and go from there.
Most likely keeping it, biggest (only) worry is "suspicion of defect" by an over zealous Officer in which case id be reamed big time as I have stuff all stock parts & can't deal with the hassle of inspections while at Uni, associated costs, etc. Only been pulled over once in my ownership for a RBT but admittedly its on my mind a fair bit..... Just the What-If factor.
Dunno what system you have in your state but in NZ there is a Low Volume Vehicle Certificate with an inspection carried out by licensed inspectors (not the police). I just have to get driveshaft loops and then an inspection which costs $400 -$600 and then a certificate stating that all my mods are safe i.e. that the braking and suspension are suitable for (more than) the doubling of stock power, that the seats are properly secured in short that all non oem stuff is fit for the pupose. You also get a plate to go on the bulkhead and then just have to point out the plate and if necessary pull out the certificate if you ever get stopped by the cops.
Yep, we dont have anything like that. If the police pull you over they can send you to be inspected for suspicion of having modified the vehicle even if they know nothing. Read countless stories on SAU about guys having cops point out "Turbo timers" in their engine bays which are actually alarms, etc etc.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
