alex, maybe dale can turn something on a lathe for you?
Good idea. I hear Dale's doing nothing these days anyway...
Lol, I'm a freaking bludger; all I do is sleep & whinge... :yucky:
We can have a look on Saturday mate, we just need to find how much room is needed from the back of the aperture.
Might be able to knock up a trial & see what works. :thumbsup:
yeah dale doesnt do anything except fabricate stuff for stagea people. isnt that his fulltime job??
Lol, AND I've been working for my Ceramic Coating mate in his workshop doing some performance fabrication; currently stuffing a 4AGE Turbo into a KE10 Corolla, and just about to start a 20 valve into a Sunbeam Alpine...
The Corolla is nearly finished; most of what I've been doing is modifying pipework to run a full plumb back blowoff valve setup (engineering requirement), and mounting an airbox under the passengers side front guard; as there's no room in the engine bay for anything at all.
Some pics of the KE10;
Lol, tonnes of room to the brake master. Hope the engine mounts are stiff!
Would be fun. What's the chassis like in those, stiff or soggy?
Yeah, I know; I wasn't involved at that stage, but it has very stiff engine mounts, they're based on a 4WD leaf spring shackle bush in a custom mount.
The front has been modified from a transverse leaf spring :blink: , to coilover struts with big brakes, and BIG swaybars front & rear; but I don't plan to go anywhere near it when it's finished.
It's going to be deadly.
Nice. :)
I fit a 1J into a T18 Corrolla for a mate a couple of months ago. No engineers cert required for that over here apparently. lol.
Nice. :)
The T18 was a pretty ordinary handling car from the get go; must be a bit of work to make one go 'round a corner with a 1J...
I do like the way they sound though.
1J's that is... :whistling:
So less than 24 hours after getting the new wheels on, actually did some impromptu tarmac rallying...
Coming along a suburban street at night, in the dark, doing the posted limit (60), and all of a sudden the car hit a dip and got what felt like pretty serious air - felt like it cleared the second dip, and landed down on an angle, drivers side first. Classic rally style.
Wish there was photographer!
Car looks fine, no obvious damage. Woman and I were ok, I just had a headache from where my head hit the roof pretty hard.
Turned around to see why there wasn't a sign warning of the dip to see there was, but the council hadn't pruned the tree in front of it, and the sign was completely obscured when approaching from the direction I was approaching from. Other direction is fine, both signs are clear and obvious.
Will try to get it up on the hoist next weekend and have a proper look, but it feels and looks fine, so I'm hoping it hasn't done any damage to anything I can't see.
Far out! hope everything is good.
Anyone watching the streams of the LeMans 24hrs? shattered the deltawing got put out early. Never was competitive, but would have been good to watch it go round.
The sideswipe that put delta wing out was interesting. As was Anthony Davidsons back breaking crash. Poor guy.
What stream are you watching Alex?
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
