yeh i bought my first car through these guys, within a month there was an engine knocking sound, eventually the engine just wouldnt turn on. within a month, just after the 30 roady period finished. and extended warranty never worked.
Edited by Sunkist
  • 4 weeks later...
lol you lost kents.
i do want a PM35, but later, i think i want an evo for now
lol, sounds like you are certain about one and unsure about the other.
Never too early to buy a PM35 Stagea... then got to 3.8L (or 4.2) and turbo ;)
correct - but PM35 will need a family to fill, and still with me not doing so much audio anymore, theres no need. plus to add my dog isn't even the size of one of your dogs legs, so she wont need to be in the back.
evo is still a powerful out of the box four door - hopefully. plus not enough PM's in melb.
Don't Emo Aaron. You've done the car to be like everyone else, don't do it again.
hey atleast i stopped with the backwards cap.
i need to conform a little.
And?
So get an 86 and mod the crap out of it
And?
nah i've driven them, and wasnt too happy with what your getting.
there is a lot of better things to spend on road costs of $40k on. to be honest.
Lancer Evolutions = skilled driving for the skillless driver :P
Iain,
I drive a 270kw RWD car with no hicas no ABS no Traction control
triple heavy duty brass button clutch
in manual.
i think i've proven myself enough lol
let me buy an evo.
yours sincerely
a beverage.
Let him buy an evo... Nice cars. I had a 92 GSR, loved it, drove a go kart!
Bit easier than a floating boat, but I have a family. Including a big f'n dog ( not the wife lol )
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
