hahaha If only the nissan stagea came in ute form right?
Find me one of those and I'll buy it.
will go for a test drive later this week... I owned a Ford XR6 a while ago, thought it was good for the money. does anyone know if the holden is capable of having the hook points on the outside of the tray for the soft Tornau??? Because when i owned the old Ford that was the best thing about it... i've seen the new soft tornau's and how they latch up on the inside personally i think the older ones are better.
The commodore soft cover setup is MUCH better than the clips, and Im a ford man through and through.
both the L98 and the 4L turbo are excellent engines.
the ford will carry more in the tray.
but either way I would be happy with any of them.
You mean 98 ron?
-shakehead-
Also what fails, is holden's "brand new touchscreen" system.... Soarers came out with touch screen dash in the early 1990s -.-
Go FPV
Yes they also came with an AUD equivalent $100,000+ pricetag too. Technology always filters down to the family car maker after prestige are done with it - you didn't expect Holden to make a profit off selling a $20,000 Commodore with touch screen and electric seats at the time did you?
Both these cars are great...in contrast to zebra, I'm a Holden man...but over the years I've come to appreciate both Holden and Ford for how far they have come with the vehicles they are producing. Forum opinions are useless for this kind of thing unless there are known problems with one or the other...go test drive them both and flip a coin if you get stuck. You probably won't look back with either choice.
Being the owner of a FPV and a Ford, I am a bit biased, but your choice of a BF FPV Tornado vs a new SS-V, I would get the Holden.
The reaosn is the new commo has better tech than the BF. If you put a SSV and a New FG XR6Turbo ute, I would get the Ford.
The Ford FG is so much nicer inside than the Holden and will also carry 1ton, be more responsive to mods (300rwkw under $3k) and if you get the ZF auto is a gearbox made in heaven.
good points, I'll book in for a test drive of both later this week and we'll see how I go. it's 50/50 at the moment hahaha.. I've heard great things about that ZF gearbox too, but i'm undecided whether it'll be a manual or auto, thats the next question.. cheers for the opinions though.
do u want a current model or a BF FPV????
the bf was produced up until 2008
Heres a BF FPV F6 Tornado
and here is a
Holden SS-V Redline Ute
i like holdens better but i dont mind the BA-FG shape
depends if u like V8 or Inlne 6 Turbos, just test drive and you will see
Edited by ML73ZR
and here is a
Ford looks fcking tough i reckon, the pros about the SS-V redline is that it will come with everything electronic, like GPS, reverse camera, ipod and etc...
I've got someone who would tune the ford too.. mean sucker once you get going. thanks for the input.
i like both of them. i would simply have to drive them both before i bought either. i do like the thought of the turbo 6 so i would probably lean towards that.
my sister in law's ex had a BA XR6T sedan (just the 240kw one with the 4 speed auto). got a flash tune off CAPA. before the flash (dead stock) he made 248hp (185kw). with the flash tune he made 299hp (222kw), but i can't remember whether that was at 9psi or 11psi. also that was a generic tune (basically a standard map with a slight tweak for the boost increase). the car was never put on the dyno for the tune or anything like that, so there would've been plenty more in it had he had a full tune done. even still, at 9psi it was pretty impressive. gave the feeling like it was holding back a lot too. you'd floor it and it would accelerate well (thanks to a buttload of torque), but you could tell the generic tune and low boost was holding it back and there was a heap more power there just waiting to be unleashed.
Hmmm, sounds good, what are the main differences between the FPV F6 tornado and the normal BA XR6T Ute?
F6 had better brakes, suspension, larger turbo and obviously more powerful (270kw rather than 240/245)
Also the different body kit and better interior bits.
Probably just better everything :)
Really comes down to whether you want a V8 or Turbo 6... and whether you want a brand new car vs 2nd hand.
Only thing I can think off is that if you are going to get one with auto transmission then the Ford's ZF 6 speed auto box has the advantage over the Holden's 6 speed auto box, from what I have read at least...
Only problem with driving an XR6 turbo is you have that "I just bought the fastest car on the road" stigma of the atypical XR6 turbo owner. It was much worse when these cars first came out though, very reminiscent of the great midlife WRX crisis of the 90's.
The SS's sound pretty good though, especially with an exhaust. Bang for buck mods the ford will have more power, but in the end, what are you chasing?!
hahaha, can't chase anthing, unless it's on the track... ute will handle like a bucket of shit though.. more for work purposes, plus tax saving too! :P
Easy and relatively cheap power to be had with the FPV, more so than with the holden. I'm very happy with my bf xr6t with the zf auto.
One thing though you're mentioning a 2 year old fpv and a new holden? Why not compare an FG xr6t/f6 as well?
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
