  • Replies 58
sell missus
keep car
LOL. +1
My Lady has set it in stone that I have to keep the car. This is how it should be.
+1 I'm not into blokey blokes, but no one has the right to ask you to sell; saying this I told Brenton he's not allowed to sell the FTO.
I wish my dad had a skyline when I was in school, Instead I got picked up in an old piece of crap 1989 tarago with him playing loud horse racing from sports 92.7AM ;)
I wish my mum had a Skyline, I used to get picked up in a Datsun 200B and an LJ Torana in Primary School and then high school was either the '94 Toyota Camry or the 88 Mitsubishi Lancer
lol..
i got ferried to school in an slk once...
Seen this car in person at the vicimports cruise..fkn awsome car man. Trust me youll regret it if you sell it...i know its a different ball park but my dad sold his old school ford gt when i was born cause i was the first kid on the way and he still regrets it coz of there value now..(not saying the gts-t's are gunna go up) but you know what i mean...KEEP IT!
Knowing her, I can totally see that. :P
Mine wants me to get an R35 GTR. :P
Back OT.
Honestly, I agree with the guys above - the car is most likely worth more to you than to most.
IF you really need to fix a finance problem, I'd look at the parting out option. Can be a bit of work, but as most said, will be a better result.
Good luck either way. :)
why not? he could use the money to buy a sports car
LOL!
well, your kid will get to be ferried to school in a skyline, he/she's lucky too..
Yeah, Tyler likes cruising in my car...It's very plain at the moment...waiting to earn some real money then hopefully people will stop calling it a commodore, and it can live up to it's badge
LOL!
people are just jealous that they cant afford a sports car and the closest to power they can get is from falcodores.... :rolleyes:
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
