Yeah at street power levels the extra valve train weight is more than made up for by extra valve area and the fact you have dual cams meaning less compromise with valve timing, however is it possible that at extreme rpm of 10-11k which some of these motors see that the extra valve train loss could become an issue, does anyone know if more or less lift can be achieved with single vs twin cam rbs?
Plenty of twincam RB's at 12000RPM+++
Not sure on the lift though although I woulnd't assume so.
Think about it, at higher flow levels the increased area and variability between INLET and EXHAUST with added tuneability becomes an even greater benefit.
  • Replies 59
This is what I would have assumed as well, just trying to get an idea about why the records aren't basically the asme, probably has nothing to do with actual power and more to do with the cars.
Yeah mate, that's pretty much what I've assumed as well.
I'll throw in my 2 cents here.
I own a high comp Tomei 2.8 with a set of decent cams with a pair of GT RS's hanging off the side of it. After driving a 3 litre with -10s (MarkoR1's) and being in N1GTR's car with a very similar setup I would not even look at the 2.6, 2.7 or 2.8 engines. It almost wants me to throw mine in the bin and build a 3 litre + engine. All that rubbish you hear about "30's dont rev" is exactly that.... a load of crap.
Don't throw it away Paul; just leave it out the front and I will come get it :P
a block in crappy condition in the us goes for a minimum of 1k in the usa, they average around 2k not including machine work, belt, headgaskt, gaskets, and yadda, bare minumum is 5k for a 3 liter block to be operational in the us, i would just do a 2jz...
shipping a whole engine block would cost at least $500 if not more, $1k is probably a pretty accurate outcome for buying a $100 block shipping it there and some markup to make it actually worth while.
Edited by Rolls
Agreed. A well built/balanced RB30 can rev to 8 and beyond without rattling itself to pieces.
The head and turbo combo is the key for sustaining power all the way up there though.
Mine is going to 8000rpm maybe more if the head allows :whistling:
sadly i think i will never achieve the 3 liter status, if my stroker 2.7 dies, i am going neo and calling it a day lol, i would love to get a rb30 though the two i have seen were ridiclous.
current mods:
t517z turbos
264 greddy cams
trust front/dump pipes
trust PEII cat back exhaust
trust 720cc injectors
power fc d-jetro
os giken twin plate
basically i wana build the ultimate stagea in all aspects power, looks, interior the complete package and wana make 600 hp+ at least to make the wagon really quick due to its weight, it will be a show then street car. the budget i have is approx. 40k for engine.
If you want to build the ultimate Stagea you will have to go north of 600awkw (not 600hp) to beat Psymin's ultimate Stagea. He used a 2.8 stroker kit but bang for buck Rb30 will get youi there cheaper - see Spool or Proengines or RIPs: http://www.ripsltd.com/
"Click."
Edited by dirtyRS4
thanks for all the ideas and advice i will let you know what happens and i know about PSYMIN's stagea and if i wanted to build the ultimate power stagea i would have to go north of 757kw but thats not what i'm after. I'm after a show quality stagea big custom stereo, custom paint and engine with power to back it up so it isnt all show (which i have yet to see anyone do to a stag PSYMIN being the closest). Thanks again for all the help will keep you posted.
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
