I have seen one of the ex pace cars. It was completely factory except it was British racing green but was so long ago I wouldn't even know where the car was anymore.
Edit: I was told at the time it was the pace car for the 92 Bathurst and if you watch footage it was definitely a British racing green Aussie Gtr
Yes....... The car you are referring to was Bob Roman's (Autotek) Recaro/Momo promotional car.
I have a few articles on it and I'm sure in one of them it comments on a black to green paintjob.
It had numerous different paint/wheel and trim schemes.
Here are a couple of articles on it, unfortunately I need to go to work so I post them all up.
It looks black in the attachments but in the actual magazine you can clearly see it's a dark metallic green.
Cheers,
Bob.
Good work bob!! that is the car, when I saw it 10 years ago it had a different set of momo wheels on it and now that you say it I remember them mentioning it being a momo promo car.
When I get home from Fiji I will ring my friend to see if he still knows where it is
Ok....... Sorry for the delay but day to day life got in the way.
Attached is a new spreadsheet with the correct build numbers matched to VIN's in sequential order from lowest to highest.
With the correction surrounding the 15145/16145 anomaly (myself included), anyone who has/had a build number under 45 needs to deduct 1.......... I go from 27 back to 26 etc.
The final count of colours within the 100 ADM's is:
  • 44 Red Pearl Metallic's - Paint Code AH3
  • 32 Black Pearl Metallic's - Paint Code 732
  • 24 Jet Silver Metallic's - Paint Code KG1
Based on my research and information supplied within these 50+ pages, these numbers are much more in line than the previously published ones. The 37/Red, 37/Silver and 26/Black theory just doesn't stack up.
Whilst as a matter of respect to my informant, I won't post up a complete list of colours mated to VIN's but if anyone has a one off enquiry, I'm happy to supply the info via PM's.
Cheers,
Bob.
Hey Bob,
Can you confirm what colour is supposed to be on build number 016045.
Regards,
Hey guys, I thought I would update you on a recent purchase........
I purchased build number 63 a few weeks back and unveiled it at last weeks 25th Anniversary get-together.
She needed a little bit of TLC which was given. It's now getting close to being where I want it to be.
Cheers,
Bob.
  • Like 1
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
