What is the book "Aussie Godzilla" that you are referring to?
Is it a properly published book with ISBN, or does it exist online with a weblink?
Thank you!
Here you go..........
http://www.pitstop.net.au/products/aussie-godzilla--the-r32-gt-r-arrives-downunder/
Cheers,
Bob.
From what I know it was imported before Nissan did?
Wrong colour but worth adm money if right?
From my understanding, only the 3-4 prototypes plus the 100 documented ADM's are worth ADM money.
That said, even the prototypes are debatable.
Some say they are worth more, some say not as much. It's a tricky one I guess.
I know little about the Scuderia cars.
If they are just grey imports before Nissan finalised their 100 cars then that's what they are...... "Grey Imports" and should be priced accordingly.
I don't see why they should bring a premium, let alone ADM money.
Could anyone clarify exactly what they are?
Thanks,
Bob.
Have to find a good second hand unit local (try FS car parts & accessories $50ish)
New appx $850 AUD from Amayama
No Idea if Nissan parts could help you out or be cheaper
Second hand ones are not worth the effort. Better off with a reconditioned item.
My brother has owned 001 of 006 ever made Scuderia R32 GTRs since 1999 I think...it's original as per factory. Jet Silver Metallic :)
Only 6 were made which was sold locally back in 89. It does not carry any ADM parts such as roof aerial, tail lights, side indicators etc.
They were fitted with the n1 body kit (front bar snorkels, bonnet and boot lip) and also has unique Scuderia branded dash, bootlid badge and compliance plate).
If u search the SAU rare skyline thread I did post pics a few yrs ago.
Edited by Marko R1
Not really as they were sold here in Aust with local compliance. The changes on the Scuderia are not really far off the JDM, but then again the ADM is also not far off from the JDM which I think makes the Scuderia as valuable as the ADM...then again, Its probably the rarest R32 GTR which might even outweigh the ADM.
Edited by Marko R1
Yeah Scuderia in VIC imported them and sold here as new. He has full documentation and the service log was a joke...7k for a service back in early 90s. My brothers car in particular was sold in 92 as it was on the showroom floor at Scuderia for its first 3 years of its life.
We have had no luck in tracking down the other 5. Ive looked for years on the net with nil result. Probably ended up as race cars hence cannot track them as registered vehicles, or written off
Edited by Marko R1
Just spotted in South Hurstville a maroon ADM with plates 1959CF. Sorry couldn't get a pic...another one for the list which I need to update
OK......... We have a problem with that one.
I ran a check through myRTA rego and history check and that rego comes up as a 2006 Ford Falcon!
Either it had an other states rego plate of the guy is swapping plates to avoid number plate recognition in police cars as the car would be unregistered.
Cheers,
Bob.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
