Hi StagMan...........it did not see on the fire wall .....i would think it would be pretty easy  to see....its not hidden away somewhere
silly is it.............i didn't think so.....lol............thats ok...............its still a MONSTER..........thanx again for your help
Cheers Jon
Cheers Jon
28 minutes ago, MyBrosBaby said:
Hi again....ok here are all the numbers of the blue ID plate in order from the top
IE-BNR32
BRN32-000O906
KBNR32RXFSLMZG
KH2   G
RB32DETT 2568
FS5R30APRC41
The "P" in the last line could be an "F".....can't read my own writing.......i'd go to the car but it's not where
i'm sending the email from............thanx again.............Cheers Jon
That decodes to;
BNR32-000906
aug 1989 build
series 1 Japanese Import GTR ( not Australian delivered)
KH2 = gunmetal grey metallic
Very early build GTR with that chassis number.
Update LOL- Duncan you beat me to it.
Edited by RS4StagMan
Hi...you guys are really sick...i luv it.......i recently acquired the car with the passing of my brother..........hence the name.
It is gunmetal gray....Recaro seats....is that standard?........but from what he told me its got a lot of really good bits on it.......what they are i am unsure of......but .........10.9 for the quarter is better than my Fairmont at 11.9 and i know how quick that is...............do you all meet sometime?
Would be great.....your knowledge is incredible......would luv it pick your brains and have a beer at the same time    again thanx for the
input......Cheers Jon
  • Like 1
On 27/01/2017 at 1:26 PM, MyBrosBaby said:
Hi Everyone....Happy New  year to one and all.......looking for some help trying to find out if the recently
acquired 1992 R32 is an import or one of the 100 Aussie delivered cars............Thanks for your input.........Cheers Jon
968 R32 GT-R's were built in the first month of production being August 1989.
Yours is one of these cars....... Courtesy of the GT-R Registry here is the data - http://gtr-registry.com/en-r32-colours.php
Congratulations........ Cheers, Bob.
NOW......the million dollar question..........i gotta have this baby insured..........be real nice to know that the GTR geek world think that should be............i can look on EBAY and assorted sites and get an idea but because of its build date is that relevant to its value.....Jon
20 minutes ago, MyBrosBaby said:
Hi.........as i said your knowledge is incredible...........can i assume that August 1989 was the first release of the car.....and this car was in the first batch of cars made????
Yes correct......... Bob.
Ring Shannons and NRMA Veteran, Vintage and Classic Insurance.
Impossible for us to quote without seeing photos let alone the car.
Bob.
  • Like 1
Hi..i'll do that..............my Fairmont is insured thru Shannon.........just curious to what you guys thought......it is unmarked and when washed and clean looks brand new.....interior is spotless..........has all original mats......stroked and bigger turbo's.....some smart engine management....
its currently at the mechanic getting the roady for the historic plates........cannot wait get get behind the wheel.........again thanx for all the info.............hope we get to chew the fat at some time..............Cheers Jon
Hi Marko..............cute daughter.............thanx for the condolences ............i check with them ....but i might get a good deal as its the second car i'm getting insured thru Shannons......this is weekend research....i picked up the car last Wednesday........Cheers Jon
  • Like 1
  • 4 weeks later...
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
