Hello everyone, i am going to be selling my ADM R32 GTR (Chassis No 6F4KBNR32A0016028) in the next week or two so thought i would let you's know first before advertising elsewhere. Car is all original and is silver build number 17 - 100 i shall update with photo's and details over the weekend.
  • Like 1
20 minutes ago, RB26DETT 240Z said:
Hi Robert, its Cuong with the black ADM gtr, I've sent you a PM
A black ADM next to a silver ADM would look nice in the garage :) oops I just realised you didn't pm the owner of the silver ADM
Edited by Marko R1
Error
Hello all again here are the details of the beast
Colour : Jet Silver KG1
Delivered : May 1991
Sold : 05/10/1992
Number : 16 of 100 ( 016028 )
Kms : 261 750 ( Service History, Log Books and Receipts )
Dealership : Westpoint Nissan Qld
Owners : ??? Maybe the 4th
Purchased : 30/04/2013
Located : Perth Western Australia
The car is all original condition with no modifications and has all service history, log books, receipts, spare key, touch up paint ( unopened ) and do have items that I have collected over the the 4 years that will be sold with the car also. If you have any questions feel free to call and ask away and I can be contacted on 0423 549 665 Robert.
Car is located in Perth Western Australia
Asking price $ 42,000 ( Custom number sold with car )
P.S Have had difficulties uploading photo's so shall try again in the next couple of days
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
