What set-up are you coming from?
Done so far: 3" stainless turbo back. Fmic. Coilpacks. Fuel pump, ecu, digital boost controller, turbosmart stealth plumback bov, custom airbox, intake and exhaust cam gears.
Adding in this install:
Gtx3076 .82, injectors, fabricating 4" intake from custom box to turbo, fabricating stainless dump pipe to suit Garret housing, exhaust manifold gasket and bolts, powder coating everything black (turbo, piping, braided lines etc)
Er. I think that's it.
My GTX3071 finally arrived, the 1.06 rear housing is way too big but I may use it to jig up the adapter and pipes then try it out. Whats the worst that can happen, a bit of lag? Lazy to build boost?
i think it'll work pretty well actually. would be similar to a 3076 with a 1.06 rear, which is what i have and its perfect on a 3L. would be a little laggy on a 2.5 but should still do nicely.
Thanks Zebra. Yep, it wont be too bad hopefully as im up around 4k whenever I hit the throttle. :P
It was the only Tial housing available unfortunately, even GCG are out. I will probably go the .82 when they are back in stock and hopefully the Vbands are the same size. Either way I needed this housing for the VQ35 build if I ever get the coin to progress it further. Parts are so cheap to import atm too damnit.
might be a little different in twins but i think with a smaller housing you'd find the rear housing would support a fair bit less power than the gtx71 compressor can flow. might be better off with normal 3071s and smaller housings
HKS T2 flanged housings, GCG stock them.
would those be the gt2835r ones ?
ps: would you guys think x71r in twin cofig with the t2 housing posted above would be semi-responsive (20ish psi no later then 4500)
Edited by KISIN
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
