Noticed this in the turbo upgrade thread... Unfortunately it doesn't seem to help in any way in telling what the turbo is like because the curve is a dog of a thing (I'm guessing boost control is all over the shop), no boost level was noted and also inlet temps would allow for a fair bit of correction power wise!
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=340033
Edited by SimonR32
Did any one see this result from GTX3071 in .82 rear housing? It appears to be pretty laggy thou. even compare to a normal 3076
link here
http://www.skylinesaustralia.com/forums/topic/55845-rb25-turbo-upgrade-all-dyno-results/page__view__findpost__p__5815898
Agreed, it shouldn't be dropping up high either with the .82 rear. Perhaps the 1.06 was a good idea after all. :whistling: I wonder what boost?
I should have mine in soon, just completed the fuel system.
Twin Walbro 342's, separate 6an lines to each rail.
Did you use proper fuel rated power supply cable to the fuel pumps?
I'd take that one with a grain of salt, something in that setup is potentially a bit dicky I suspect. Looks too laggy, even though GTX turbos seem to be laggier than the GT counterparts. Hope the owner joins the convo and gives more info.
The question is: how much better can the GTX be? Its a new compressor wheel stuck onto the same old exhaust wheel.
I am least surprised with the results, factors I believe contribute to their lack of excellence must be related to the step away from high and low blades along with larger trim sizes in general. I note that the EFR still use the high and low blades.
I think it would be a nighmare to develope such a product in a lab, you have to have the backing of a real world performance application to be successful with this sort of product. If successful surely Garrett would have plastered it all over the web to show everyone their marvel, however there was no such talk. I suspect these were purely lab bred items with limited environment testing.
Scotty, not to discredit your setup, I hope it works out really well and I also have faith in the bigger housing. Your workmanship thus far is also VERY impressive, GL.
Don't forget that's the shonkiest power curve I've seen yet on a tuned car with supporting turbo....unless it's wheelspin
Perhaps, but the exducer tips are on a nice 40 degree angle which I haven't seen before, and the front housing has huge flow. I was very interested to see the potential of the compressor and running the tial 1.06 rear shouldn't choke it at all. Im not sure I can reach the the full output potential with my gearbox anyway but im guessing an easy 350 on e85, perhaps close to 400 at stupid boost.
Didnt forget it at all, I basically said something was clearly up and figured that people reading the post would know exactly what I was referring to by looking at the plot. Don't know if its a dodgy tune, or something is up with the motor or what - there are various possibilities... hence not being specific :)
I am sure it could do better than that, though I had hoped the GTX3071R was going to be the most likely unit to prove its worth from the get go however remain unsold on the GTX turbos.
biggest problem with that is the .82 IW housing will become a big restriction before the compressor reaches it limits. apart from that though it should be a good comparison, especially for spool
The 1.06 will be a waste of time though imho, if you are going that big you may as well go up to a GT35 based howside with a smaller a/r turbine housing... they seem to drive nicer imho.
So you have you driven a car with a GTX3071 and Tial 1.06? :)
I didn't have a choice as Tial are out of stock of the .82 and .63 worldwide and the other flange types just wont fit where I have mounted it. Like I have said, this housing will be perfect for the 3.5L I am building. I am hoping it frees up the top end and gives me a more gradual boost curve, I didn't like the way my highflow snapped on at 3k anyway.
GT35's aren't my favourite turbo, I have heard of too many failing, even at low (less than 20psi) boost, perhaps because they are so common?
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
