Anyone considered the new GTX3576 for an RB ?
http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=TP&Product_Code=GRT-TBO-185&Category_Code=
Reported to have same boost response of a 3076 with more power of a 3076 as per post 33 of this thread link who is a Garrett employee.
http://www.nissanroadracing.com/showthread.php?t=3241&page=4
The gtx3076 can't match a gt3076 for response I can't see the gtx3576 matching it
Might have misguided you with my previous post ...to clarify..... .the GTX3576 is reported to match the GTX3076 for boost response and make more power.
Edited by juggernaut1
This doesn't surprise me too much, the GTX3076R seems to behave like a GT3082R - in response and power from what I've seen and people I know have gone from GT3082Rs to GT3582Rs and been surprised and pleased to report the response is no worse, but they get more power.
Imho this renders the GTX3076R and GTX3576R redundant when there are cheaper alternatives in the form of the GT3082R and GT3582R, respectively.
No straight up comparisons which I have heard of tbh, but so far FP GT3076R have made the highest power I've heard of from GT30-based turbos and they also spool better than the vanilla GT3076Rs so I'm already sold that the FP unit is the better option, given they're clearly both going to be limited by the GT30 hotside and the GTX seem to struggle to match the GT for spool/response.
  • 3 months later...
I have been looking to upgrade the GTX3071 and cant find many reviews on the new GTX3576, it seems to be the best compromise for the new compressor's efficiency.
Hopefully I can find one of the new split Vband inlet turbine housings in GT35 size when they get released in around 2-3 months. Check out the Sema clip for the new housing i'm looking at. No word from Garrett yet as to what turbo's it will fit, it seems to be installed on a GTX28...
Divided t3 internal gate gtx2867 on an RB25 would be epic for a quick streeter
Those red turbine hosuings look like wax/plastic rather than Iron
I agree, it would almost mimic the stock turbo's boost curve and then just keep going. I would guess over 300kw on e85 if the housing flows well enough.
The housings haven't been released yet so you are right, they would be plastic pre-production models. By the look of the wall thickness it will be made of investment cast stainless. I just hope they make them for other turbo sizes...
ROFL @ sensible.
Any in any case, if you put 2 twin scroll turbos on an RB you have a '3s a crowd' situation X 2.
That being said, we will all have to go VK56s in tube frame front ends. There, I fixed it.
My gut feeking is that Garrett have a bit too much compressor capacity in a "GTX3076R" and their partial fix is to use a GT35 turbine with the "76X" wheel to get GT3582R type performance .
Time will tell if the GTX3071R becomes the replacement for the GT3076R 56T .
^ Agreed, I have to say I called the GTX3076R pointlessness ages ago - before they even showed up on cars.
GTX3576R sounds like it makes more sense, though I'd rather just use something already on the market that already spools and responds better than a normal GT3582R but makes way more power as well (GT3582R HTA).
The GTX3071R haven't yet done anything which make me feel like they have made the GT3076R redundant that I have seen yet.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
