Well if you can't get an RBR out of Q1, even without KERS, and on the harder tire, you can't really say too much...
Exactly...they were saying that kers gives a 0.3-0.4 sec advantage on this track...webber wasn't even near that...excuses again...
So hoping Vettel doesn't just drive away again. Would be great if his kers bails and that long straight serves as a battle ground between Button and Vettel. That might be asking too much though? Do the other back-runners have kers? Are they going to launch past Webber like last week? Hopefully he recovers well, it's going to be a bad GP for him and he'll be fighting all afternoon, but i bet he'll get some points out of it, assuming no-one takes him out.
Look forward to reading about wtf happened with that tyre choice and lap time.
KERS is no excuse for being that far down the field.
i wanna see him do well....but it just keeps going backwards. I'd say if he doesn't do well this year he should/will retire......or they are deliberately making his car suck balls so he can help hold the rest of the pack back so Veetool can win easier, and to give them an excuse to ditch him next year for someone else? Barichello maybe? he likes being second fiddle to German elitists doesnt he?? :domokun:
either way...i dont see it hapeneing for Webber. maybe he needs some prettier arm candy to BOOSt his confidence?
theres already enough ballast in the drivers seat holding that car up
Bahahahahahahahahahahahahaha
Poor webber, I feel sorry for him sometimes. He's certainly one of the best drivers, but he's never had luck on his side.
Redbull's now the top team, they may want someone like Di Resta, Petrov or Rosberg for some new blood in 2012. Though ferrari still stick with massa (I think webber>massa though)
Edited by Galois
Cause Weber will be holding a lot of Vettel's challengers back from 18th position on the grid. Unless he lassoos the cars in front to get a bit of a run up the straights.
WTF with Weber? wrong tyre choice,be interesting to know the real story on who made the desision. Not suprised to see KERS not working on mark but just fine on sebs, same cars my a@$
I'm mystified. The simple fact is an RB7 should be able to get into q2 on 7 cylinders, never mind hard tyres. And mark's a better driver than that ... at least, I've always thought he was. He's still the same guy that came close to winning the title last year, but I have to ask if his head's right. I wrote off Australia as a one-off, in Malaysia he was screwed by the KERS failure, but I can't think of any reason for this qualifying performance except him being out of the game mentally. He can fix it but he needs to take a good jar look at himself, I think
Webber also only managed 5 laps in P3 and only one of those was a timed lap, seems something has been up with his car all weekend he was way down in the other practise sessions as well. Whatever the cause without KERS here it will be a very long day for him.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
