I've been saying that since the mid 90's and here we are lol.....
my new formula would be:
3.0 Litre DOHC 5 valve per cylinder max twin turbo V10.
Or upto 8 Litre naturally aspirated, any configuration.
Free aero, apart from front and rear wing wake and air disturbance massively reduced.
Full ground effects floor, tunnel and diffuser allowed.
No kers or any other device of this nature.
alcohol based fuel.
minimum two tyre manufacturers.
cockpit equalised so that no driver is held back by weight or size.
Larger tyres, much different profiles, probably 18"
If full ground effects were allowed back (sliding skirts, tunnes... etc) the cars would have tiny wings anyway, regardless of rules.
I think the old 1.5 turbo or 3.5 na is the way to go, but leave the piston count and layout free. The turbo tech that would come out of low capasity engines would be great
by the looks of the rule changes...i dont think i'll be watching after 2013 anyways. so they can all do what they like
good point. I figure if I up my alchol consumption by about 30% I will soon forget all the WDC results from 1985 to 2000 and I can then just re-warch those 15 years of F1 over and over again...
yeah agreed. 3l turbo and 8L na is waaay too big. get them to make a max 1.5L turbo or 3L na as the maximums. they can easily get 800hp-1000hp from either 1.5L turbo or a 3L v10 NA so then they get to chose reliability (800hp) or power (1000hp). or spend more and have both!
if really generous up it to 2L turbo and 3.5L NA. that is plenty.
I like the idea of cockpit rules though and perhaps raise min weights so that fat drviers aren't penalised! lol. i'm sure there's some talented fatties out there... would surely help webber to be on an even keel weight wise with vettel. he is giving away probably half a tenth per lap in body weight penalty alone.
....actually the way Raikonnen is going on the tooth he might need an extra widebody F1 car if he makes a come back.
I wonder what mods they made to get Tony Stewart in the MP4-23 did they graft the A to B pillars from a BA Falcon with a seat located in the middle to fit him in? It would have left room for space to sit a pizza, a couple of burgers and cupholders for a big gulp.
I would love to see more taller/bigger drivers have a shot at F1 but realistically it is a sport for rich midgets.
alcohol based fuel.
then i'd def be watching. :)
sadly.....very unlikely
I'd be happy to keep the current capacity, what is it 2.4L? They can make plenty of power from that capacity these days. But allow whatever configuration they want to run as far as how many cylinders etc, and have no rev limit.
It could give some more variety in the field, the way its going it will be a common pretty much everything ala V8 Supertaxi's in a few years.
No rev limit could potentially reward teams willing to push the limits of engine reliability if they can hold them together. I don't see the problem with that because they already get penalised for using too many engines anyway, so why not let them push the envelope of reliability?
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
