Was so dirty when vettel topped it. Hopefully hamilton will do a "banzai" on vettel in turn 1, vettel would not be sleeping soundly tonight with hamilton next to him.
Button and Alonso on the grippy side, turn 1 could be very interesting!
Edited by Galois
lol yeah webber's back in form. 1.5 sec off his teammate.
his helmet probably creates more drag or something
Hamilton may have got him without the mistakes into the final turn too.
absolutely. that little oversteer moment definitely cost him more time than he missed pole by
http://www.autosport.com/news/report.php/id/93507
Colin Kolles deserves a punch in the throat.
You know your running a joke outfit when your singing the praises of a deal that nets you a measly $1 million per season extra, but on the other hand takes viewing from free to air television.
Must really take a load off the catering bill down at HRT, what a cockpuppet.
i'm thinking he may actually get away ok this time. he will wheelspin it for the first few metres (instead of bogging it down) until he gets onto the clean strips left by the car in front of him taking off. and then get going well.
ah who am i kidding. he'll be down the back by the first corner
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
