First off back in 2003/2004 I imported my first Gts-t... Was a great little fun car with a RB20 and Apexi turbo making 220 odd rwkw
http://www.youtube.com/watch?v=lp2QUSzZFa0?fs=1&amp
http://www.youtube.com/watch?v=jf7fbJvImwY?fs=1&amp
I then sold that, purchased a R32 GTR (spun a big end bearing about 10 days later) and then begun the process of rebuilding the motor and strapping on a T04Z. Ended up with 430rwkw and the thing was a bullet but I needed to move on with my life and buy a house so I sold it :P
So I had got my house but was missing all the fun (and annoyance of owing a R32)... I found this Black manual Gts-t (with a shocking white bodykit) for sale one SAU for cheap!
Unfortunatley the reason it was cheap is the owner had fallen asleep at the wheel and caved in the front end, so this is how it got back to my garage (had been partly dodge fixed)...
  • Like 1
https://www.sau.com.au/forums/topic/345095-another-r32-money-pit/
The car was pretty much stock with a cat back, it needed a fair bit of work and I took the time to do some basic stuff while it was off the road.
Removed all the HICAS lines and pumps etc and fitted a lock bar (saved about 20kgs)
Removed all the air con (saved about 30kg)
Whiteline Castor kit
Whiteline subframe bushes (Pineapples)
Bought some 17" Gtt rims
Fitted factory Type M skirts and pods
The sunroof was stuck open, most the paint was pretty fvcked or had different colour panels so I tried a few DIY paint jobs and failed so I ended up getting it running and taking it down to my mate who is a painter over here in Perth BBK.
Just about ready to leave after putting it all back together!
On the way to get painted...
Half painted :D
Back at home
Edited by SimonR32
So I got a little carried away with my suspension, ripped out the parts I had already installed and decided that rose joints pretty much all round should do the trick ;)
HKS Hypermax Rear coilovers and Top Secret Fronts (came with the car)
Kazama Castor Rods
Kazama Ally Subframe Lock Bushes
R32 GTR Rear Swaybar
Rear Adjustable Camber Arms
Rear Adjustable Lower Control Arms
Rear Adjustable Traction Rods
Edited by SimonR32
Care to share what brand those lower arms are?
All the blue arms are from performance-guru off ebay (from the land of the sheep shaggers)
I did a bit of research about them before I purchased and they are made in Taiwan not China, seem to be very well made and I know some people who are using them in drift cars for a few years now and they are still holing up strong.
Website to company that makes them http://www.si-racing.com.tw/
Power time :blink:
Installed
Walbro GSS-342
R34 GTR Injectors and Ballast Resistor
Z32 AFM
Nistune Board
Just Jap Bell Mouth Dump pipe
De-cat Pipe
K&N Air Filter
Hypergear low mount ATR43G3 with a 0.63 Rear
Turbotech Bleed Valve
Add 22psi on BP98 and viola!
Also added some front camber arms
It was time for a bit of a driveline beef up, looks pretty much stock under the bonnet as well :whistling:
Front mount and Pod filter = 260rwkw
OS Giken Triple (Overkill)
R33 RB25DET Gearbox
ATS 1.5way Mech Diff
Edited by SimonR32
How do you find that turbo on the RB20?
Very good top end, very average down low... But that pretty much is every turbo on a RB20!
Got bored with 260rwkw so decided to do a E42.5 mix. 50% BP98 and 50% CSR Sucrogen E85 (we don't have any E85 here on pump in Perth)
Comparison of BP98 and E42.5 (same boost level at 22psi)
So after stripping 3rd gear I got a little miffed that I had to punch gears so hard just to keep the little 20 in the power band...
I hatched a plan to chuck a RB25 in the old girl and keep most of the same supporting mods :)
That didn't go to plan because I was thinking about everything too much so I have ended up with this plan
Nistune RB20 ECU and loom
Greddy MSS for switching VCT
Yellow Jacket Coils
740cc top feed Deatschwerks Injectors
Ally fuel rail
Bosch 044 in tank
Z32 AFM in cooler piping
VH45 Throttle Body
Freddy Inlet Plenum
6boost manifold
Kinugawa (Kando Dynamics) T67 10cm T3 Rear
Tial 44mm MVR Wastegate
Stock RB25 motor
Adjustable exhaust cam gear
Greddy Profec B Spec II
Getting started, RB20 out and RB25 in the hole
Edited by SimonR32
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
