interested to see how u go with that turbo i have been thinking about using the same one except low mounted on the stock manifold with a spacer/wastegate adaptor. but im thinking its gonna be restricted greatly by the manifold so i might just use their td06L2 with the 10cm rear.....
Exactly what my plan was until the turbo arrived... The front compressor housing is big (like a Garrett 0.7) and it was going to need like a 30mm spacer!
In the end I figured getting a spacer, another gasket, the exhaust housing welded etc was all going to be a headf**k (and decent cost) so I just ended up going a 6boost. Plus as you said the standard manifold was probably going to be a restriction at the power I'm trying to make.
The TD06L2 10cm also seems like a good option, I think the only difference being it is water cooled as well. Plus I have read that the 20g front wheel really runs out of puff at about 270rwkw
PS. Shouldn't have to wait long, car is going to be on the dyno this week (fingers crossed maybe even tonight)
T67-25g 10cm Photos
Tial 44mm Gate
6boost Manifold
Looks pretty good :)
Edited by SimonR32
Turbo looks good, Simon & Battery, the T67-25G and the TD06-20gL2 share the same turbine wheel and housing, the difference is the T67 uses a TD07S comp wheel and housing, which is also the same as the TD06-25G
the adaptor i have is similar to this...
but yeh that t67 is pretty big :) ill be putting it into a 33 which i think will give me a little more room?
i'd love a 6 boost but im not really interested in paying the $1300 to get one!!
there seem to be a few guys pushing 260-270kw with the td06L2 8cm rear on sr20/rb20, so i think it may be possible to get to 280kw with the 10cm rear...
Keep looking around for a 2nd hand 6-boosy, I sold mine which was a twin scroll T4 for $500.
yeh i could stomach $500..
i think ill wait for simons result before i decide on anything, should be interesting...
what are the lines and fittings included in the kit like?
Oil feed is good (you need a fitting to go into the block), oil drain was a tad short so we are replacing with a braided line (better to be safe with heat + oil = fire)
I'm crossing fingers for results tonight... All we have to do is the oil drain, dump pipe and gate screamer pipe!
SO, sick of toasting RB25 boxes behind a 20 so you throw a more powerful RB25 engine in front of the same sort of gearbox? :) Any excuse to lose the RB20 ay? :)
Interesting to see how it goes...you guys are just rough bastards. My car will hit 200,000kms this weekend at Winton and its still the original gearbox !
Don't you like my reasoning haha
Roy I love my RB20's and always will, but times are changing and I just couldn't see a way to keep up with the Jones without going more capacity :)
Got some results via text message, made another 100hp will post graphs soon
Actually ended up going 517rwhp (386rwkw) without correction...
So that is a 127hp more than the RB20, plus it's 700rpm quicker to come on boost and nearly doubles torque between 3000rpm-5000rpm
Does nothing but burnouts in pretty much all gears
I know what turbo my 1jz is going to get now!!@!@!@!@1
What fuel? Throw some decent suspension and tyres at it now.
I've got all adjustable links but my rear shocks are not the best... I have a pair of RE55's at home but don't want to lap them on the street so the plan is to get some KU36 and see how they grip.
I'll post the graph up pretty soon but it makes 15psi at 4000rpm which is a bit later than STATUS results but it may be because of the fuel (which seems to make turbos laggier on most cars) or because the turbo was literary brand new when it drove on the dyno with no run in.
Still massively impressed with the results, the car feels about on par for pace as my old GTR which makes for a scary RWD
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
